Old 04-24-2012, 02:00 PM   #11
Triguy's Avatar
Thanks All!
Good points to consider for either (or even both 30 and 50).
I meet on Friday with an electrician so he can look over my setup and give me a quote. I'll ask him to quote the various setups you all mentioned.
I have no idea what the costs may be. From the sound of it, there could be quite the difference in $$.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-24-2012, 02:23 PM   #12
Herk7769's Avatar
Late to this thread. Out voting.
Some things to keep in mind:
1) Electricians need to understand that this is an RV plug and not a dryer plug. More than one thread here about some electrician friend wiring the 30 amp RV plug to be 220. Bad mess; it will fry all electronics in your camper.
2) While you can run 10 gauge 2 wire w/G for a 30 amp RV circuit, it won't work for 50 amp.
Shop Cerro Wire 10 AWG 50' Indoor Non-Metallic Wire at Lowes.com
50 feet of 2 conductor 10 gauge with ground $62.50
Additionally you will need 3 conductor w/G for the 50 amps service and two adjacent 50 amp breakers in the breaker panel.
Shop Cerro Wire 8 AWG 50' Indoor Non-Metallic Wire at Lowes.com
50 feet of 8 gauge 3 conductor w/G required for a 50 amp service $120.00
Left Hot; Right Hot; Neutral and Ground.
HAM CALLSIGN - KC3FFW
Old 04-24-2012, 02:24 PM   #13
TURBS's Avatar
I know this sounds stupid but make sure your electrician
Knows its 30 amp 110v not 220v
I've seen this happen with a union electrician.
Old 04-24-2012, 02:24 PM   #14
TURBS's Avatar
Herk u beat me to it!
Great minds think alike
Old 04-24-2012, 03:09 PM   #15
Triguy's Avatar
Herk and Turbo,
It doesn't sound stupid. I've also heard of electricians not familiar with RV services.
Along those lines. I spent some time last night on RV Electric trying to find some answers to my previous questions.
It didn't cover what I was looking for but helped me to understand a bit more about the differences between 120/240 volt appliance services (like what I have for my dryer) and 30- and 50-amp service for an RV.
I appreciate the words of warning. I intend to pass this along to the electrician.
Scott
2012 Shamrock 233S
Old 04-24-2012, 03:41 PM   #16
Herk7769's Avatar
Here is some info for the 30 amp service.
Even if I had a 50 amp coach, I think I would just go this route.
I doubt you would need to run both ACs in your driveway.
Old 04-24-2012, 04:25 PM   #17
PINTO
Kpinto's Avatar
Correct me if I am wrong, but 30 amp is wired 110V and 50 amp is wired 220V. If you do run the 50 amp you would also need to be the adapter from 50-30. More money.
PINTO
2011 Flagstaff 8528 TBWS
2008 Duramax Diesel
Chevy 3500 LTZ Dually
Kpinto is offline   Reply With Quote
Old 04-24-2012, 04:40 PM   #18
Absolutely not. 30 amp rv is single 110v, 50 amp rv is 2 110v lines. It is not like your dryer hookup. You can make a 50 amp rv into 220v with a special plug. Don't know if they make a plug that splits a 220v into 2 separate 110v required for a 50 amp rv plug.
I guess I should have said an adaptor that plugs into a 220v receptacle and coverts it into a 50amp RV receptacle or 30amp RV receptacle.
Old 04-24-2012, 05:10 PM   #19
Herk7769's Avatar
Well, this is a fine kettle of fish.
Let me see if we can clear this up.
As I understand it. A 50 amp plug is two 110 volt legs.
This is typically made with a 220VAC 50 amp breaker in the panel (this is so a short trips BOTH legs of the RV outlet) Red wire to one side and black wire to the other); a 3 wire w/ground 8 or 6 (depending on distance from the panel) gauge wire to the 50 amp RV socket. The pin out for the socket gets the red wire on one hot; the black wire on the second hot; the white wire on the neutral and the bare copper on the ground lug.
So everyone is right. It is 220 VAC at the breaker panel but arrives at the RV plug as two 110 "circuits." Electrically, the RV socket back to the panel must be wired as a 220 circuit because the neutral has to carry the return current from two legs. It can be the same size as the "feeds" because it will only carry the return current from the two legs only one at a time. 1/60 of a second alternating between the two legs.
If you actually wired the two legs from the same PHASE of the panel you would either need two neutrals OR one twice as large as each leg. If you did the one phase thing, any 220 VAC appliances in your 50 amp rig would not work (like a dryer).
Old 04-24-2012, 05:17 PM   #20
Herk7769's Avatar
Click on this link and select 50 amp service.
RV Electric
50 amp
