Old 04-24-2012, 11:30 AM   #1
Triguy's Avatar
Should I install 50 amp or 30 amp service?
We've decided to keep our trailer at a new location in our yard that is closer to the garage.
But, I do not have 30 or 50amp service available there and plan to install something. Our trailers have always been 30amp as is our current Flagstaff Shamrock. The trailer will sit 25' from the box.
One more thing that may help: We do not plan to upgrade anytime soon to a larger 5er or MH that would need 50amp (although that is a distinct possibility 10-12 years from now). Who knows if we will even own the house.
So, my questions are:
  • Do I just go with the 30amp because that's all we need?
  • Would there be any benefit to having a 50amp for my current 30amp trailer? (I don't think so but I've been wrong before ...)
  • Is there a big cost increase between installing a 50amp instead of the 30amp? This is not something I want to do on my own and I will have an electrician install whichever one for me.
  • Assuming we go 30amp now, is it hard or expensive to add 50amp to the same box in the future?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-24-2012, 11:35 AM   #2
I would bite the bullet and put in both 30 & 50.
Old 04-24-2012, 11:42 AM   #3
Oakman's Avatar
30 amp should be sufficient for your needs. If at a later day you buy a motorhome or trailer that is 50 amp, all you need is a 30 to 50 amp adapter to plug into the electric box.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is online now   Reply With Quote
Old 04-24-2012, 11:52 AM   #4
Dave_Monica's Avatar
Would you be planning on running two air conditioners on a camper parked there? Otherwise, 30A service should be more than sufficient. Also, pricing the wire size you'll need for 50A will help you decide.
Dave
Old 04-24-2012, 11:54 AM   #5
Send a message via Skype™ to scubieman
I would recommend 30 amp. I have 15 amp for my camper right now. I will only use fridge and vacuum at same time so that's all I need and its already there.
So it depends what you plan on doing with RV there? Just cleaning and packing for next trip then I would say 30 amp. If someone could stay in there for a weekend since house is full I would still say 30 amp. Even if you have a 50 amp RV does not mean it needs to be connected to 50 amp service. Plus 50 amp is more for running 2 AC's at same time. Unless it gets real hot where you are, I would say save the money and get a 30 amp.
2009 Dodge Ram Mega Cab 2500 6.7 cummins
2011 Forest River Cherokee 28BHKS
scubieman is offline   Reply With Quote
Old 04-24-2012, 12:00 PM   #6
Price from 30amp to 50 amp will cost about double, possibly more. However only running a 25' span the price would not be too bad to do for 50 amp. I would go that route because you never know.
~Andrew
99 F250 Super Cab Short Bed 7.3 Powerstroke
84 24' Yellowstone Camino (oldie)
http://rvpdi.com
Acableguy06 is offline   Reply With Quote
Old 04-24-2012, 12:15 PM   #7
TURBS's Avatar
If money is not an issue run the 50 amp it will cost more if you have to run it later and then your 30 amp service is negated .
Old 04-24-2012, 12:42 PM   #8
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
Just a thought - since you probably (per code) need to dig a trench anyway, why not run water at the same time?
dimurrrw is offline   Reply With Quote
Old 04-24-2012, 12:51 PM   #9
Run wire heavy enough for 50 amp, but only put in a 30 amp breaker and 30 amp plug. If you decide you want (need) to go bigger in the future, just swap out the breaker and plug and voila!
2012 Flagstaff 8528 BHSS
2008 Ford F250 Crew Cab 4x4 6.4L Power Stroke
fordmantpw is offline   Reply With Quote
Old 04-24-2012, 01:59 PM   #10
cre10's Avatar
That's what I would do.
2012 Chevy 3500 Duramax Crew Cab Z71 LTZ SRW
2012 Cherokee Grey Wolf 28BH
2011 F-250 6.2 Gas
2001 F-350 Powerstroke
1995 F-350 7.5L 460
Numerous Ford and New Holland Tractors up to 135hp. Bobcat 773.
cre10 is offline   Reply With Quote
50 amp
