Originally Posted by janice parker
why the ground wire??
Because as you're in there fumbling with a wrench on a terminal nut, there's less risk of causing a short and arcing the wrench to the body. If you were disconnecting the hot and touched anything metal around it it can arc.
It's a good habit to get into working on anything that's a negative earth system.
