Old 11-16-2012, 08:45 AM   #1
Oklahoma Proud
MillerTime's Avatar
should you leave plugged in w/batt disconected?
So if I unhook my battery for the winter, should I unhook shore power to the trailer when I'm not doing anything in the trailer? Or should I leave plugged in and switch converter breaker off?
Old 11-16-2012, 09:11 AM   #2
trudinator's Avatar
Our TT stays plugged in 24/7/365, thus no need to remove the batteries or switch the converter off. If you leave it plugged in, you can leave your batteries as is.
2012 Rockwood 8293RKSS
trudinator is offline   Reply With Quote
Old 11-16-2012, 09:17 AM   #3
Camper Less Camping
Cajun Po-Boy's Avatar
No need for shore power if battery disconnected (I'd recommend a battery tender while unhooked & check water levels periodically).
2013 Sabre 32RCTS-6 (sold)
Cajun Po-Boy is offline   Reply With Quote
Old 11-16-2012, 04:49 PM   #4
Oklahoma Proud
MillerTime's Avatar
I just didn't know if it would burn up the converter leaving it plugged in with battery disconnected
Old 11-16-2012, 06:49 PM   #5
TURBS's Avatar
Newer progressive dynamics converters DO NOT need a battery to function properly.
While wfco converters also do not "need" a battery to run you cannot move slides or jacks without the battery
Old 11-16-2012, 08:22 PM   #6
Oklahoma Proud
MillerTime's Avatar
Yep I have the wifco. I guess I'm just lazy, i could go out and try it and see what happens- afterall I still have 6.5 years of warranty!
