Old 04-15-2016, 07:09 AM   #11
Originally Posted by 25FKS View Post
The shunt goes in the negative wiring between the battery bank and the negative bus bar. See image from a website explaining. Send me a PM for additional info.
Agree. In your case, the negative buss bar is the chassis!
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 04-15-2016, 07:29 AM   #12
270S's Avatar
I love people speaking for me. No I will have actual bus bars (and set up) as shown in the diagram. I will have a connection f(wire) rom the bus bar to the chassis to enable FR wired items using the chassis as the negative BB.
I do a lot of work in the marine industry that has a chassis made of "plastic". No shortcuts there. All wiring is connected in "complete" circuits vs using a chassis for a negative backbone.
Again, once I finally pick up my TT (Next Month - Yeah!), I'll post pics.
'17 270S
270S is offline   Reply With Quote
Old 04-15-2016, 07:48 AM   #13
I love people speaking for me...
No, I wasn't speaking for you...I was trying to avoid confusing the OP who was going to put in bus bars but now will not need them for installing his shunt, which was the subject of his original post. You are kinda late to this thread.
2015 335DS
Old 04-15-2016, 07:56 AM   #14
270S's Avatar
No offense taken, but I was hardly late - my reply was on page 1. I was just trying to provide an overall picture on "how to do" to make it easier to visualize for those less familiar with the concepts.
'17 270S
Old 04-15-2016, 09:17 AM   #15
Originally Posted by ScottBrownstein View Post
Yep. Technically that would do it, presuming that you mean the "posts" of your shunt. However, I assume that they are 12 volt, so battery number one's positive post has the load from the coach and a short positive wire to battery number two's positive post. You should run a negative to the shunt from battery number two's negative post and a short negative from that post to the negative on battery number one.. That way both batteries have equal length cables, one with a short red to the other and the second with a short black.
This way both batteries see equal load and equal charge with one having a shorter negative path and the other having a shorter positive path. Like the 12 volt in the diagram.
I am using 6 volt Batts and wiring them up as 2 banks of 12 volt. Using a 1,2,both disconnect to make the parallel connection.
My interconnects are the same length. My positives from each bank to the switch are equal and my negatives which will go to the shunt are equal. I'm also going to make the pos. and neg. from the charger equal length.
Sent from a field
opie is offline   Reply With Quote
Old 04-15-2016, 09:19 AM   #16
Perfect...you have it down pat now.
2015 335DS
Old 04-15-2016, 07:42 PM   #17
Success.
Ran out of daylight and the boy has a recital tomorrow morning so I didn't get the trimetric hooked up. Tomorrow after I spray for mosquitos.
Sent from a field
Old 04-16-2016, 06:32 AM   #18
270S's Avatar
Just like in a chain or tug of war, the weakest link is the source of problems. You have different size wires. They should all be the same AWG. The red positive ones going to the switch and the red positive out of the switch as well as the black negative ones. Also, use as little length as possible - turn both small positives 180 and probably reduce their length 50%.
'17 270S
Old 04-16-2016, 07:17 AM   #19
Have made this point countless times. Why use 2/0 between the batteries if you use #4 or 6 from the batteries to the loads? It won't hurt, but it won't help much either. Shorter the better but then it is probably 15 feet or more to the load anyway, so what difference does another 6 inches make?
2015 335DS
Old 04-16-2016, 08:25 AM   #20
270S's Avatar
Like wise. I will not get into arguments. The point of Forums is to help, learn, ... never have ____ contests. I have had nothing but constant _____ since I joined. If this continues every time I post helpful ideas, I'll just stop assisting anyone anymore. I have 40 years experience doing this - take it or leave it, but keep disagreements off unless there is a valid reason, especially if one is not the original poster.
Like politics the relied on foundation is wrong to start with - if the wires are sized too small too (4, 6 awg), then they should be changed/upgraded too. Just because the windows leak air is no reason to not fix a leaky door first or in addition.
I do not know what the factory wiring is internally or user modifications have been done by members, but using the Famp rule, the proper size wire awg can be determined. In DC wiring proper size is CRITICAL! In AC too , but there is more leeway due to lower currents involved.
I have asked the factory for an electrical wiring diagram for my TT, but have been met with gigantic resistance to provide anything. This is a major flaw in their customer relations. I'll be sure to reemphasize this at some point. Heck the inverter, generator, .... everthing I've installed in a ________ has come with wiring schematics & drawings. This is a first for me.
'17 270S
