Old 08-27-2012, 05:34 AM   #11
Anyone else
2004 Sierra 330RL 5th Wheel
2002 Silverado 2500 Duramax 4x4
States I have camped in
lonewolf is offline   Reply With Quote
Old 08-27-2012, 07:05 AM   #12
Are you sure this not a Hydro system? Youroo!!
youroo is online now   Reply With Quote
Old 08-27-2012, 07:30 AM   #13
If it's hyd I'm thinkin the sylnoid is not set right.. my guess is the stop is not set correct.. or a faulty sylnoid.
diegro is offline   Reply With Quote
Old 08-27-2012, 04:25 PM   #14
Yes it is hydro the solenoid is strapped to the motor. It was working fine a few weeks ago so it just started this past week.
Old 08-27-2012, 05:53 PM   #15
caper's Avatar
Have you lubricated the arms of the slide out? It sounds as if the slide is binding on something causing the relay to open. When the relay cools it allows you to move the slide. Plus there should be a switch that will allow you to bypass the bedroom slide and allow only the dining room slide to open.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 08-27-2012, 06:23 PM   #16
The cylinder with the least resistance will move 1st,thus your bedroom like stated. Then your L/R slide. I would check your fluid level and the area where it is stoping 1 ft short. If you need fluid also check for a leak in the system. In regard to the slides moving independent by Your selection,very Few units are plumed that way,regardless of Price. Youroo!!
Old 08-27-2012, 06:29 PM   #17
Originally Posted by lonewolf View Post
Here is a picture of what I am talking about. It only does it when you bring the slide in.
That is a reversing solenoid, not a breaker. The breaker has to be on one of the power feed lines going to one of the spade connectors. We use these solenoids for reversing direction on electric wenches.
Old 08-27-2012, 06:42 PM   #18
AquaMan's Avatar
There is an auto re-setting breaker under the copper bar you spoke of. My 365 did the exact same thing. You can test this by jumping the breaker after it has "popped", you'll have about 7-10 secs before it resets itself. If the slide starts working, you have a bad breaker. The last time I was out camping, I had to let the breaker reset about 10x's. The dealer installed a heavier breaker and all is well.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
AquaMan is online now   Reply With Quote
Old 08-27-2012, 08:01 PM   #19
(There is an auto re-setting breaker under the copper bar)
Can you tell me what I am looking for or what it may look like??
Old 09-03-2012, 03:22 PM   #20
Ok I found the re setting breaker. My question is can the breaker be weak just on the reverse side and not while extending the slides? I have greased the slide rails but it still kicks out.
