Old 06-17-2012, 07:04 AM   #1
Slider will not move
I just brought my Wildcat 5th wheel home from the RV center...state inspection and some sealing work was done. When I parked and leveled the unit and tried to extend the silder room (sofa and dinette), nothing happened. No clicking sound...nothing! This has never occurred before and the room certainly moved in and out before I took the unit to the shop. I checked the fuses in the panel inside the RV. No blown fuses there...are there fuses for the slideout located somewhere else...under the room and along the wiring harness, perhaps? The battery was checked and it is "new" and the RV is hooked up to the house current. I have never had this problem and I do not even know how to crank out the room manually. Can anyone help me with this problem...2001 Wildcat 5th wheel. Thanks
nikemart is offline   Reply With Quote
Old 06-17-2012, 07:14 AM   #2
Trace the positive cable from the battery. Usually a main breaker, with a small reset button on one end. Won't be more than 5 feet from the battery itself, whatever storage compartment it is in.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 06-17-2012, 07:28 AM   #3
slider
Thanks for the reply. I traced the positive lead and no luck...no breaker and no reset button located in the battery compartment.
Old 06-17-2012, 07:39 AM   #4
It's there. Actually should be two of them. One will feed the camper, and the other will run the slide. A quick check, since you are on hooked to AC, measure the voltage on the battery. Should be over 13.5, as the converter will be charging it. That will verify the camper breaker is good. Just a matter of finding the slide breaker. usually behind some kind of panel in the storage compartment with the battery. Never seen one without the breaker, so it is there. Don't know how far you chased the positive lead, but keep going.
LadyWindrider
Old 06-17-2012, 08:36 AM   #5
Oakman's Avatar
As Windrider said, it's there. You're just not recognizing it. It will be itsy bitsy reset breaker that is nothing more than a very small black button. It needs to be pushed in. On my previous 2004 Wildcat it was actually behind a protective rubber cover. Look again.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 06-17-2012, 09:48 AM   #6
TURBS's Avatar
I'm glad they put my breakers right out in the open!
Keep looking!
Old 06-17-2012, 05:42 PM   #7
slider
Thanks everyone.
I must be blind. I traced the wiring as far as I could in the battery compartment...yes, I took off the protective rubber cover and looked at everything...found the color coded wires that match those of the inside switch, but never found the "itsy bitsy" black button. Next step...crawl under the RV and look under the slider. If no luck, I'll call the shop tomorrow morning and ask for assistance.
Again, thanks for your comments and attempts to help...much appreciated.
Old 06-17-2012, 07:28 PM   #8
bikendan's Avatar
any chance the battery was taken out and put back in, while at the RV center?
crossing the battery wires is the most common cause of setting off the resettable breaker switch.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-18-2012, 07:56 PM   #9
Oakman's Avatar
Here's a photo of the reset buttons (mini-breakers) that I was talking about. The little black spots on the side of the connection are the buttons. Even if this isn't the solution to your problem, it's good to know about these reset buttons.
Bob and Joyce
ATU Local 788
Old 08-25-2012, 04:39 PM   #10
slide won't move
Rather then start a new thread perhaps I can hook on to this one. I have 2 slides with the rear stuck open in a state park, no electricity. We manually cranked the gear to retract the slide. I also had a problem with the batteries and replaced both house batteries. When I replaced the batteries is it possible that I needed to reset something as explained in the thread? Checked the fuses and they are good. Thanks
ljcpmc is offline   Reply With Quote
