Old 01-17-2013, 02:14 PM   #1
B47
Small Portable Generators
The February, 2013 issue of Popular Mechanics has an article regarding electrical generators that can be installed in homes in case of an electrical power supply interruption. A sub feature in the article speaks about small portable generators that supply up to 2000 watts and test results of 4 different makes/models - the Briggs & Stratton P2000, the Generac iX2000, the Yamaha EF2000iS and the Honda EU2000i.
I do not use a portable generator, so I do not know if these models are similar to those used by RV owners that need them.
I found the tests to be informational and would certainly use the information if I was to purchase one.
Note: there is a 11-07-12 sticky posted here regarding a recall notice for the Honda EU2000. The sticky says the recall notice is for the Honda EU2000, but the actual recall is for the Honda EU2000i, which is the model tested in the PM article.
I thought this information might be helpful to those who might be considering purchasing a small portable generator for use in their RV.
B47 is online now   Reply With Quote
Old 01-17-2013, 02:29 PM   #2
Great Horned Owl's Avatar
You definitely want to get one of the inverter generators. They are far quieter than the older type and use much less gas. With an inexpensive parallel kit, you can hook two together in order to run your A/C.
The 2000W Honda and Yamaha are the "gold standard" generators for RV use. However, Champion, Boliy, Kipor, Generac, and several other manufacturers have models with virtually identical specs that can often be found at 1/2 the price of the big two.
Champion in an American company and parts and service are readily available. I am less certain for some of the others.
Joel
2011 Silverado 2500HD Duramax, 4x4, crew cab, long bed
Palomino Puma 253-FBS, 27' 5th wheel
1994 19' Class B on Chevy chassis
Great Horned Owl is offline   Reply With Quote
Old 01-26-2013, 03:32 PM   #3
TURBS's Avatar
Did popular mechanics have a web link to these comparisons?
I'd like to review there findings and comment.
Turbs
Old 01-26-2013, 04:58 PM   #4
B47
Turbs
I have since given the magazine to my neighbor and I don't think there was a link. But PM is online and perhaps you can get it there.
Old 01-27-2013, 09:51 PM   #5
Small Generators What Size?
How do you determine what size/capacity small generator is right for you? I have a Rockwood A122 and would consider buying one for use in National Parks to charge battery. Could be useful to run heat pump, fridge and micro.
Mhodson54 is offline   Reply With Quote
Old 01-27-2013, 10:32 PM   #6
handbuilder's Avatar
mhodson54 - I have a 2000 watt Champion generator for my A Frame. It runs the heat pump, fan, fridge and microwave nicely. It does not support the A/C - the initial draw blows it everytime. I am ok with it tho, as the cool cat fan kept temps inside cool & comfortable on 100 degree days & with the roof fan on low, it also helps to draw out the heat. The generator is extremely quiet and at 43 lbs or so, easily portable. When I run it on econo mode it lasts a good 8 hrs or so. I have considered a larger 2400 or 2800 Yamaha or Honda but as long as my Champion satisfies our camping needs, I will hold off the brand name purchase. (DH says he'd rather buy a second Champion and bring as needed). Since we are outside for most of the day anyway, having a fan instead of the A/C is just fine for me. My friends usually find me on my recliner under the awning after a day in the sun. LOL
2012 FR Flagstaff T12SDTH
1996 Shadowcruiser Pop Up Truck Camper
1967 Newell Motorcoach
2003 Ford F150 5.4 V8 Triton Super Cab
2004 Nissan Titan LE 5.6 V8 4x4 Crew Cab
handbuilder is offline   Reply With Quote
Old 01-28-2013, 09:24 PM   #7
bikendan's Avatar
by what you want to run on it. if you want to run the a/c, then the btu's will dictate how powerful a generator you'll need.
if you want to be able to run everything but the a/c, then a 2000w one will do that.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-28-2013, 09:28 PM   #8
TURBS's Avatar
this may help you some as well
normal appliance amp draws
Old 01-29-2013, 06:01 AM   #9
lindy's Avatar
B47; you said that the article listed generators that could be "Installed in Homes". I hope the articale went on to say NEVER RUN A GENERATOR INSIDE YOUR HOME, OR CLOSED GARAGE!!! Those of use that use them all the time understand this, but every year you hear of people running them inside and then being sickened and even dieing from the fumes.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 01-29-2013, 10:27 AM   #10
B47
I don't have the article here anymore, but I am sure it contained all the necessary warnings. The sub article just compared the 4 poerable generators.
Good catch.
