Old 12-03-2015, 11:22 PM   #1
RV Vagabond Jerry
Jerry Dixon's Avatar
Small portable inverter to save electricity
Is there any battery saving advantage to using a small portable inverter plugged into a 12 volt receptacle in an RV?
Jerry Dixon is offline   Reply With Quote
Old 12-03-2015, 11:30 PM   #2
Fulltime family RVer
Versus what?
Old 12-04-2015, 12:36 AM   #3
RV Vagabond Jerry
Versus using the RV's built-in inverter. I hear it drains batteries 10 times faster than using 12 volt appliances.
Old 12-04-2015, 06:46 AM   #4
TURBS's Avatar
What are you going to plug into it?
Old 12-04-2015, 06:55 AM   #5
A32Deuce's Avatar
It all depends on the load as to how much it draws.
A32Deuce is offline   Reply With Quote
Old 12-04-2015, 07:12 AM   #6
We carry a 400w Xantrex inverter. Use it for charging small 110V only things like shaver, tooth brush, camera, etc. It draws about 1-2 amps with no load. The 1500w built-in Xantrex in our old motorhome drew about 7-8 amps with no load.
Plus I can carry it in the Jeep to recharge the camera, etc. during the day and on trails.
dontay is offline   Reply With Quote
Old 12-04-2015, 08:57 AM   #7
AquaMan's Avatar
I don't know about 10x faster, but there is a loss factor when using an inverter. Most are around 80% efficient, meaning there is a 20% loss. Larger inverters usually have a fan also that has additional draw.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 12-04-2015, 09:13 AM   #8
TURBS's Avatar
Am I wrong in thinking that it really doesn't matter if you have a 1000 watt inverter or a 5000 watt inverter if you plug the same thing into either it's going to draw the same?
Old 12-04-2015, 09:59 AM   #9
Who Dares, Wins
doc73's Avatar
I would have thought, but the poster a few up said they knocked a few static amps off by using a smaller inverter..
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 12-04-2015, 10:04 AM   #10
TURBS's Avatar
Sounds reasonable.
electric, inverter
