Old 06-08-2015, 08:58 AM   #11
Flybob's Avatar
If you have the WFCO convertor and you leave the RV plugged in 24/7 then you may have one or more battery cells with little or no water as the WFCO convertor does not have an intelligent trickle charger. You can check the water in the battery to see if that was the problem, but if that is it, you should replace the battery as it will have incurred some damage.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-08-2015, 09:02 AM   #12
waiter21's Avatar
The answer is Yes, you could do that; i.e. remove/disconnect the converter, and use a battery charger to recharge the coach battery.
You will need to make sure you do not over charge (boil the battery) or under charge (run the battery low ) These will both kill your battery in a short time.
The converter not only keep the battery charged, but it actually supplies the 12 volts to your systems when your plugged into shore power or running on a generator.
Without the converter, your battery supplies power to the furnace, water heater, frig, lights, fans, etc.
I don't like large power fluctuation getting into electronic equipment, connecting disconnecting a battery charger will give these fluctuation. Also hydrogen gas will be developed when you deep cycle the battery, so use caution when connecting/disconnecting the battery charger (
Keep an eye on the fluid level in the battery (you should be doing this anyway, but more so if your deep cycling the battery.
My recommendation would be to replace the converter with a three or four stage unit. This solves all the problems.
I've delt with these folks, they stand behind their products:
http://www.bestconverter.com/WFCO-Converters-_c_82.html
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-08-2015, 09:05 AM   #13
The short answer is yes, you technically can delete the converter and use an external charger to keep re-charging the batteries. I would just upgrade the converter and be done with it.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-08-2015, 09:10 AM   #14
wmtire's Avatar
As others have stated, you could do what you discussed.. Many members do the exact same thing when their converter dies while out on a camping trip.
However, I don't know if I have heard of anyone doing it for except in the very short term, until they could get a replacement converter. I also don't know of what the long term implications would do to the battery (or anything else) depending on what kind of charger you had.
If it were mine, I would replace the converter with one that others have pointed out and be done with it......but that's just my opinion.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 06-08-2015, 09:11 AM   #15
Witch Doctor's Avatar
I think you have to remember, I guess you can do what you want, but a person should only draw down there battery to 50% so how long would that take? The convertor takes out your battery for most part being it is giving out 12v power all the time. So if you turn on all your 12 volt items they all can run. As far as getting hot the fixtures. Well that is true but you can always go to LED bulbs. (less amp draw) I really don't see a savings by your way, you can get a 70 amp charger/converter for about 185.00. To buy a 4 stage automatic charger would cost alot more then that. Also by your way of wanting to do it your going to need to add a amp meter so you can monitor the state of the batteries. Those are not cheap either. I have never heard of a battery being low on water to smoke a convertor, but I surly do not know everything. I good place to start is to read living on 12 volts, that might help you...Good Luck no matter what you decide.
Coachmen M/H
Concord
2018 / 300 DSC
Old 06-08-2015, 09:13 AM   #16
rsdata's Avatar
If you are never going to move, then using a "smart" charger on the batteries will work to keep your 12V power going and your battery(s) from overcharging. I would also change out all the incandescent hi-current (hot) lighting in your trailer to cool and efficient LED lighting. I purchased some replacement LED's off amazon, but also bought some from http://m4led.com
They have a real helpful website.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 06-08-2015, 09:20 AM   #17
Originally Posted by jtrader View Post
can I get rid of the converter so I'm running my 12v on the battery then straight charge the battery from shore power.
Yes. You "can" physically disconnect it with ease, but if you're on shore power all the time what would be the advantage in doing that? There would be a little more wiring that would need to be done ($), you would still need to purchase a stand alone 4 stage "smart" charger ($), increase your battery bank capacity ($)...
You're basically just trading out a converter/charger with a straight charger.
It's entirely up to you of course. Heck.. my converter is physically disconnected. However.. I had a specific need to disconnect it... while normal CG type camping and 24/7 shore power available I can't imagine going to all that trouble and additional expense if I didn't have to.
rana is offline   Reply With Quote
Old 06-08-2015, 09:21 AM   #18
TURBS's Avatar
Simple in my mind is trashing the $150 plus converter and replacing it with a battery charger to keep the DC side running.
Not sure that is simple, so humor me .
Everytime you go camping you must get charger out and an extention cord and plug it in and turn it on and every time you are done camping you must unplug charger and store it, wrap up cord and store it as well.
Please explain how that is simpler then just plugging in your camper and moving on to fun stuff?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-08-2015, 09:30 AM   #19
Hallo . Mine is permanently disconnected. But you're right... under normal circumstances I wouldn't complicate matters without a good reason to do so.
Old 06-08-2015, 09:52 AM   #20
If you decide to go that route you would also need to take into account the cost of increasing the capacity of your battery bank. That alone will put you over the cost of a new converter. A single 12v automotive battery would not be sufficient in type of setup.
converter
