06-08-2015, 10:39 AM
#21
IIRC, our new 1976 Golden Nugget tt, didn't have a converter, but did have dual batteries which were charged by the tv. I added a battery charger that stayed plugged in and we just plugged an extension cord to a pedestal when available. Did it until 1981 when we bought our new 81 Holiday Rambler Alumilite 5th wheel. Don't remember if it had a converter or not.
06-08-2015, 11:25 AM
#22
Silly question but did you check to see if the shore power was hooked up correctly?
2013 Cherokee 284BH
2017 RAM 3500HD Laramie, Mega Cab, 4X4
06-08-2015, 11:40 AM
#23
OK now I am going to be harsh
Unless your TT is of very little value or you get batteries for free, IT WOULD BE A STUPID FALSE ECONOMY TO NOT REPLACE THE CONVERTER. Your frig has a sensitive digital circuitry. Blow that and bye bye frig. Your batteries need a strong charger and at times your coach needs high current. When you stay on 24/7 the batts need de-sulfided and I have never seen a charger that does that Automatically. A good converter WILL. DO YOUR SELF A FAVOR. GET A NEW CONVERTER AND A GOOD ONE. THEN CHARGE AND LOAD TEST THE BATTS which probably need replacing if they have been 24/7 on the one-size-fits-all Factory converter for very long. so don't mess around just go buy the converter
06-08-2015, 11:50 AM
#24
My initial thought was to do what I think you are attempting to do. Rewire the TT to run off of the batteries with no shore power and then use an external "car" battery charger to supply the 12 volts to keep the batteries charged.
I have a 3 stage external charger. It was about $100. I have never seen on e that was 4 stage. It seems to me that it would be better (less effort for one) to spend an extra $50 on the converter.
Unless, of course, you already own the external battery charger and can dedicate it to the TT.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
06-08-2015, 11:52 AM
#25
You need a new converter. It is critical that the converter drops back to the 13.2 volts when batteries are fully charged. If the converter stays at the higher 14.4 volt charge rate the batteries will boil dry and be destroyed. That is why you need a top grade converter that will supply the needed dc and properly manage the batteries.
06-08-2015, 01:00 PM
#26
I think a little clarification from me would help matters. I stay on shore power 24/7. My wife and I full time in the trailer. I already had to replace the fridge over the winter due to a bad cooling unit. Fridge is now an AC powered Frigidaire. I rarely ever use the furnace in the winter unless it is in the negative 10 degree temps. A 1500W space heater(AC) does the job just fine. The primary consumption of DC in our TT is the lights. Even if I had LED's they still need DC without a complete rewire to AC and new fixtures which is big bucks and a LOT of work I don't need to tackle. That leaves the HW heater, RF booster, exhaust fans, and Air Conditioner needing DC power plus other things that skip my mind right now. My thought is to eliminate the converter and charge the battery either manually or with an automatic charger. Already have a good charger that could be dedicated to the TT battery and somewhat hard wired where all I have to do is urn it on when I see the battery is getting low. That's where I think the simple solution might be. Staying on top of the battery isn't really a problem in our situation.
I just got done breaking the seal on the "maintenance free" battery. It was about 3 pints low TOTAL. Each cell was somewhat depleted but the plates weren't showing that I could see. Filled it to about an inch from the top of he battery to what looked like it should normally be. Battery was made in Jul 2012 ad came with the TT. For the past 30 min I have nearly everything in the trailer that is DC turned on doing a solid test. I know I will have to replace the battery very soon and I will find out shortly (no pun intended) if the converter can still hold it's own.
My TT: 2013 Cherokee Grey Wolf 28BH
06-08-2015, 01:16 PM
#27
Yeah shore power is hooked up correctly and is on a 30A surge protector.
06-08-2015, 01:21 PM
#28
I see no reason why you can't use a charger in your situation. I would invest in LED lights though for the 12V ceiling units... they sip power from your battery instead of drink heartily like incandescents do.
2014 Shamrock 183
06-08-2015, 01:31 PM
#29
Already have some of them replaced but still have 14 bulbs to go. The LED's have been known to cause my wife to have migraines and other problems at times. Getting the warmth and lumens right have been a challenge. Getting there though. I hate these incandescents. I had to make Forest River replace all of the fixtures the first 6 months we had the TT. The switches were undersized and would melt.
06-08-2015, 01:52 PM
#30
I agree with the suggestions / recommendations to upgrade to the Progressive Dynamics replacement for your converter / charger. A good move that you will not regret.
2013 Flagstaff 8528IKWS, 2006 F-350 6.0L
06-08-2015, 02:26 PM
#31
Don't forget your slide, awning, water pump, LP/CO detectors, radio, stabilizers (if you have them), electric jack (if you have one), any powered meters, hood fan, breakaway switch, etc. Some of that you can use your TV to run, but was just trying to illustrate the mirad of little things that are easy to forget, but can add up.
Most rigs will have around a 1-2amp "phantom" draw, which you will get no return from. So with your automotive battery (without knowing the exact specs) I'm pretty confident you only have 50-85 amp hours of capacity. Most certainly not much over 105ah tops. So with a parasitic draw... in a 24hr period.. that will leave you, conservatively, 0-25ah "available" (50% SOC) without having turned on a single DC device.
With your automotive battery charger... that's fine for the auto battery you have, however, you will more than likely be in a near constant discharge/charge situation. Not a great place to be for a healthy battery and a hassle free trip.
I think I get what you're trying to do.. you have a battery and charger already, so out of pocket at the moment would be minimal if you nixed the converter. Is that about right?
Just to illustrate. Your 12v power resources at the moment... A battery, an auto charger, no converter, and shore power. You saved the $150 by nixing the converter.
A little down the road... No converter, battery is shot, an auto charger that's not really usable if you go with a deep cycle battery next time, and shore power. In other words.. no means to run the 12v side of your rig unless you fork up for new batteries ($170) and a compatible converter or another charger ($150).
I think what everyone has been suggesting (without the "long story") is that you are better off to pony up the $150 for the big beautiful converter, have unlimited 12v available now and onward, and a charger that will be compatible with true deep cycles when your forced to replace your battery (which you don't have to worry about for awhile since you already have unlimited 12v).
It puts you ahead of the game now and later with the least amount of hassle.
That being said, and if money's a little tight right now, a fella's gotta do what a fella's gotta do to go camping. I think most of us have run on a jerry rig more than once. It's entirely up to you and hope you didn't feel too pressured. Just for those that have been around the block had in the back of their minds, I'm sure, that you would be getting "more" for "less" going the converter route now.
06-08-2015, 03:07 PM
#32
Yarome I appreciate you spelling it out for me and you're pretty close to guessing my thoughts on it but it isn't really about the money.
Thing is I am looking for a long term solution. I don't "go camping". I live in this thing 24/7. Haven't even moved the powered tongue jack since July 25th 2012 and pulled the slide in twice a year to lube the seals. Point is I don't plan on this trailer being out of this spot for a very long time. Even when we move out of it this will become our "second" home and still never leave this spot. That changes the long term view.
If this trailer sits here for the next 5 years or more I will most likely be doing this all over again even with a really good converter. Truth is they are not built for the constant use I put this TT through. Every single night these lights and everything else DC powered gets used. That puts a draw on the battery and converter that they are not meant for day in and day out. Using it here and there for trips and fun is one thing but every day takes it's toll. I'm trying to think how to avoid that for the long haul. I could walk into any of many RV parts stores here and replace this converter for $135 identical or spring for a $185 Progressive Dynamics (only a two year warranty) and be just fine for the next couple years. My question is what about after that. Would that money and effort be better spent elsewhere?
From all of the replies I've gotten it doesn't seem like there is a solution that will stand the test of time. Your point is well taken about constantly being charging/discharging. Only solution for that problem is a bigger battery bank. I've considered that in addition to a solar array and charge controller. This would also help save on the electric bill which would end up paying for itself. Perhaps this converter issue will be what I need to get that idea out of my head and hooked up to the TT. Seems like that will solve more problems even if at a bigger up front cost.
For now things seem to be going ok. I've put a more than usual DC load on it for over an hour and a half now after topping off the battery. The converter is warm (as it should be) but not overheating. I'll be taking action very soon for the simple fact I don't trust this converter and battery anymore.
Thanks everyone for all of your replies.
06-08-2015, 03:39 PM
#33
Can this be done:
Turn off or disconnect the battery charging function of the converter.
Replace the battery with a 12 volt power supply of sufficient capacity plugged in to shore power.
This would require that the converter is working correctly, except for the disconnect charge function.
I have no idea how to disconnect the charge function of any converter. I don't even know if it can be done.
06-08-2015, 03:47 PM
#34
My 5th wheel has been plugged in with various items running since Aug of 2011 as I leave it plugged in 24/7 365, so with that being said I don't believe constant use is of issue.
Good battery maintenance is probably the best solution.
Wfco converters are junk which is why we recommend a progressive dynamics.
I'd venture a guess that you'll not have an issue in 5 years as long as the battery is maintained properly.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
06-08-2015, 03:53 PM
#35
WFCO converters may not be the favorite but they are NOT junk!!!
My last rig had one and we had that trailer over 6 years and our twin 12v
batteries lasted 5 years.
We don't leave it plugged in 24/7 but only plugged in when we are camping.
AT home I use a battery tender charger.
For folks who don't leave their rigs plugged in all the time WFCO chargers
will get the job done just fine.
Peace!
Dan & Rita D
06-08-2015, 03:54 PM
#36
You and oc have had the only 4 good ones ever made.
IMO they are junk.
Overseas made crap.
If you've ever had a pd and wfco side by side you'd understand.
TURBS
2011 32bhok Sabre
06-08-2015, 04:11 PM
#37
There's a difference between being plugged in and lived in. That's why it's anyone's guess how long pretty much any converter is going to last with 24/7 actual usage. That's why I'm looking at all the options. I never head into things like this without asking questions.
Battery maintenance in any RV is always pivotal. If I would have known my "maintenance free" battery could fry my converter I would have checked it every month since day one. Instead I took the label's word for it and looked no further. That's nobody's fault but my own.
06-08-2015, 04:15 PM
#38
IMO they are junk.
Overseas made crap.
TURBS
2011 32bhok Sabre
I guess I have #5 good WFCO so far.....battery mtce is key and everything has a working life, after it will fail.....
Fonzie
06-08-2015, 05:12 PM
#39
That changes things. I'm in a similar boat. I'm 365 but I travel and only plug into my genset every once in a great while.
I understand your concerns about lifespan. I know quite a number of fulltimers that have been running PD converters and other products with great success spanning many years. Then again, I know folks that can kill one in 2. IMHO, it generally comes down to how well you know your equipment, how you use/integrate and maintain it, and in general, you get what you pay for.
In your situation, being stationary, getting 5-7+ years out of a PD converter shouldn't be that difficult. But even calculating for 4 years you're only into it for about $3 a month. Not too shabby for something you'll use daily.
You really should look into solar though. It's getting so inexpensive it doesn't take but a couple 2-3 years to break even on the cost of a fairly decent system. Then it's just gravy.
My system is of the "Cadillac" variety... meaning... if people knew how much I have sunk into some of the components they would think I was crazy. But I rely on it daily, often in remote locations, was designed to be "bulletproof" and fully integrated.
Last years total power consumption was 93% solar. I calculated on a 10 year life (but actual should be 15). 4.8 years to break even.. so in 11 months I'm out from under it... controller, inverter, charger, battery bank, panels, and every wire, fuse, tie.. and everything in between added to my power systems. I'll really enjoy those 5-10 years of free juice.. I just have to live that long right?
Didn't mean to ramble, but like getting fellow full timers onboard with solar.
last years total power consumption.. 93% solar.
06-08-2015, 05:26 PM
#40
Oh ye misinformed youth of today
Those "5 good WFCO's"?? THOSE are the WORST!! They failed in their programming to self destruct at the 11th hour. If they ignore their programming who know WHAT in the heck they might be capable of!!
I would be afraid... be very afraid.
