Old 02-26-2016, 12:51 PM   #21
Fulltime family RVer
Originally Posted by TURBS View Post
You'll be fine 15 minute install.
Heck, it takes me 15 minutes to collect tools typically!
btw, your forum signature is different than your app signature w/ the # of days camped.
ependydad is online now   Reply With Quote
Old 02-26-2016, 12:59 PM   #22
TURBS's Avatar
Hmmm I better straighten that out!
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-26-2016, 01:01 PM   #23
Holy crap sickles, Tweetys is like $100 more than bestconverter.com.
PD 9280C 80 Amp RV Converter/Charger
(A prior page says this includes the $10 remote pendant.)
vs.
Intelli-Power 9200 Series 80 Amp RV Converter/ Charger from tweetys.com
plus the $10 remote pendant.
Now, shipping is frightful if I want anything quicker than ground.
Old 02-26-2016, 02:40 PM   #24
Welp, ordered from BestConverter.com hopefully $30 for shipping means it won't take too long. (sigh, you really get used to free 2-day Amazon prime shipping!).
Old 02-26-2016, 06:24 PM   #25
NOT GOOD!
.. and a b!tch ain't one. I have had some intermittent 12v issues for a while. I think each one has been a clue to a bigger issue.
Today was the coup de grase- my WifiRanger (wired into the 12v system) sketched out on me twice. At the same time, my mobile hotspot spazzed our (plugged into a 12v car charger).
This evening, the lights in the camper dimmed a couple of times. While it was happening, my wife was in the kitchen and said that they heard popping noises and we started to smell hit electrical smell.
It all seemed to originate from the converter. I shut everything down right away and started moving the breaker/distribution panel so that I could see what was going on.
I have a WFCO WF-68100A converter. The LED status light was showing amber at first and then it turned to flashing amber. According to the owner's manual, that indicates that it was off (it was, I flipped the breaker) and that my battery is showing low voltage (which it shouldn't as I'm always connected to shore power and it should keep my battery minty and fresh).
I haven't done any more troubleshooting as my volt meter sucks. But, I do plan on following the notes in another thread.
I also assume I'm just going to buy a Progressive Dynamics converter and install that. My nads are feeling big these days and I might take a stab at the install (it helps that it plugs in and my father-in-law will be here on Tuesday).
Any thoughts or points of wisdom?
Let me satrt off with that people need to learn that any issue with one item on one side of the electric is going to effect all things hence your issue with ( wifi ranger, then the hotspot as they are both tired to the 12 volt system as well as one in the same while running.
Also you did the correct thing of turning all things off, but a HUGE misunderstand of of the power systems work in rv's means that the "power converter" has not much if anything to do with the power distribution box! as the converter takes 120 volts and makes 12 volts, and all that it is the power box are fuses and circuit breakers, so i hope this helps.
And lastly you are correct, and your first thing was the dimming of the lights yes your wfco converter has bite the big one (like most do) just get a progressive or itoa converter and please make sure you replace it with a full multi battery charger so it can properly charge the battery with extra power when needed and also go into float when needed (and all the other modes) and also different types of battery's (as lithium keeps getting more popular)
Power converters are very easy to exchange and not yo badly priced as things go today
Hope some of this helps and Happy camping
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
Old 02-26-2016, 07:12 PM   #26
Thanks silverback. You confirmed everything I thought I knew (even if I didn't say it properly/outloud). It helps to read it to make sure I'm not misunderstanding.
Old 03-01-2016, 05:21 AM   #27
MCTroy
Ependydad, you can install the converter. DH and I managed to install one on our previous trailer. We took lots of pictures and made notes as we took the old one out, then used those to install the new one. We were so happy when we flipped the switch and there was light! For 2 non mechanically inclined people we were excited. So much so, we forget to finish putting the screws in. On the trip home, the new converter feel out of its base. It bounced around put was still working!
2015 Windjammer 3029 Diamond Edition
2011 Ram 5.7 hemi
Ohio River Rat
Hurry Spring 2018! We have plans ready!
MCTroy is offline   Reply With Quote
Old 03-01-2016, 08:51 AM   #28
I have to install my converter and I plan to take lots of pictures and then check the wiring three or four times before I hook up power. I plan on making sure batteries are fully charged and the negative cable is off the batteries. I don't trust myself around electric and batteries. I triple check myself
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is online now   Reply With Quote
Old 03-05-2016, 11:10 AM   #29
I swapped out the converter this morning. Overall, it was pretty easy- 12v positive and negative cables, a ground, and it plugged into the distribution panel. Pretty easy peasy.
The hardest part was the screws holding down the old 12v cables were put on by a gorilla and I got help from my father-in-law.
But, it's done. Maybe 20 minutes of work.
Old 03-05-2016, 11:21 AM   #30
TURBS's Avatar
I told you a piece of cake!
2015 Columbus 320RS
2008 2500HD Duramax
