Old 02-25-2016, 11:30 PM   #1
Fulltime family RVer
Snap, crackle, hot smell. I got 99 problems..
.. and a b!tch ain't one. I have had some intermittent 12v issues for a while. I think each one has been a clue to a bigger issue.
Today was the coup de grase- my WifiRanger (wired into the 12v system) sketched out on me twice. At the same time, my mobile hotspot spazzed our (plugged into a 12v car charger).
This evening, the lights in the camper dimmed a couple of times. While it was happening, my wife was in the kitchen and said that they heard popping noises and we started to smell hit electrical smell.
It all seemed to originate from the converter. I shut everything down right away and started moving the breaker/distribution panel so that I could see what was going on.
I have a WFCO WF-68100A converter. The LED status light was showing amber at first and then it turned to flashing amber. According to the owner's manual, that indicates that it was off (it was, I flipped the breaker) and that my battery is showing low voltage (which it shouldn't as I'm always connected to shore power and it should keep my battery minty and fresh).
I haven't done any more troubleshooting as my volt meter sucks. But, I do plan on following the notes in another thread.
I also assume I'm just going to buy a Progressive Dynamics converter and install that. My nads are feeling big these days and I might take a stab at the install (it helps that it plugs in and my father-in-law will be here on Tuesday).
Any thoughts or points of wisdom?
Old 02-25-2016, 11:33 PM   #2
B and B's Avatar
Doug, grab a charger and at least get your battery charged so you have lights etc. I would go buy a volt meter and test the voltage out if the convertor or just replace it on sept.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 02-25-2016, 11:35 PM   #3
Crap, I didn't mention that. That's exactly my plan- I'm going to keep the inverter off and will pickup a cheap battery tender tomorrow from an auto parts store to keep it topped up. I don't want another snap, crackle, pop event while we are sleeping.
I keep wanting to hit a Sears to get my voltmeter replaced, but never remember until I need the stupid thing.
And I'm thinking of just replacing the converter regardless.
Old 02-25-2016, 11:54 PM   #4
I'm thinking that I want a PD 9200 series converter, but don't know which one I should pick.
Old 02-26-2016, 04:39 AM   #5
Kenny kustom's Avatar
You don't boondock, nor do you have a huge battery bank.
I would think, 60A would be more than enough.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 02-26-2016, 05:47 AM   #6
You should Give Randy a call at best converter.com and explain your situation. He is the Obi Wan Kenobi of converters. For full timing like you do personally I would go large on the size. A lot of the benefit from that would depend on how they wired the rig and broke up the loads into circuits. It would however run cooler and cooler is always better with electronics. Call or email Randy.
Mr Havercamp is offline   Reply With Quote
Old 02-26-2016, 06:16 AM   #7
TURBS's Avatar
You have a 100amp converter?
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-26-2016, 08:27 AM   #8
I wasn't sure those amp numbers indicated.
I emailed him last night (as well as Progressive Dynamics directly).
It appears that way.
Old 02-26-2016, 08:43 AM   #9
TURBS's Avatar
Yep indeed you do!
I'd stick with the 100amp
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-26-2016, 08:43 AM   #10
Yep indeed you do!
I didn't see a PD 100amp converter. Seemed like it went to 80 or so.
