Old 10-02-2014, 09:30 PM   #1
WestCoastRV'er's Avatar
Solar & Inverter Project
Here are my plans for my new solar and inverter installation. I will be installing a tri-metric meter for more precise monitoring.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 10-09-2014, 08:29 AM   #2
250 Watt Solar Panel installed
First 250 Watt Solar Panel installed
3P ProPride Hitch
RV Mods
Wandering RV Life
Old 10-09-2014, 11:57 AM   #3
CCRVOC
Ramblin Recks's Avatar
Looks good. What type solar panel did you get?
2012 Dodge 3500, SLT Big Horn,CC,DRW,Cummins HO, EB, 4x4, 3:73, Retrax Pro, Q20, TST507, Garmin RV760, Sleek 4g
2014 Cedar Creek, 36CKTS, 640w Solar, TriStar MPPT 60, Magnum 2000w, PI EMS, WiFi Ranger Elite, Sleek 4g, Wingard DTV Traveler
Retired Army in 1995, and now retired in 2016
Ramblin Recks is offline   Reply With Quote
Old 10-09-2014, 12:21 PM   #4
deartruc's Avatar
Looking good. Campground rather tight there though. Reminds me most of our east coast campgrounds...can pass a morning cup of coffee to your neighbor without touching the ground.
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 10-09-2014, 12:29 PM   #5
mcnabbwr's Avatar
Looks really good, please keep posting as you progress I would like to do something like this, so I'm going too follow this thread.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 10-09-2014, 12:35 PM   #6
Renogy 250W
250W Monocrystalline | Renogy Store
3P ProPride Hitch
RV Mods
Wandering RV Life
Old 10-13-2014, 06:11 PM   #7
40 AMP MPPT Charger installed
25 ft (8 AWG) Solar Panel -> MPPT Charger
6 ft (4 AWG) MPPT Charger -> Battery
3P ProPride Hitch
RV Mods
Wandering RV Life
Old 10-21-2014, 10:08 PM   #8
Inverter remote switch & MPPT remote monitor installed
3P ProPride Hitch
RV Mods
Wandering RV Life
Old 10-21-2014, 10:48 PM   #9
mud yapster's Avatar
WOW nice I want to do something like that but not as big maybe half that would work for me. Nice set up I'm watching thanks for sharing.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 10-22-2014, 12:32 AM   #10
Not too shabby! If I might maybe make a couple of suggestions?
I would lose the GP watt meter and the MT-5 tracer meter and just use the Trimetric. Of course, with the appropriate shunt installed.
I would move your 250watt fuse and run it between the charge controller and your battery bank.
Lastly, I would isolate your invert from your converter. (by using a subpanel) If you're not on shore power, you'll end up using your batteries to attempt to charge themselves via the converter.
Just some smansy additions... you might consider adding a 40amp fused cutoff switch between the Charge controller and batteries.. and another 60amp fused disconnect between the batteries and your convert... then move the red stand alone disconnect between the inverter and your relay switch. For the cost, you might appreciate the additional protections, and it's nice to be able to isolate the main system components for maintenance purposes.
You might consider using 10/2 coming down from you panels and 2/0 between your charge controller and batteries... but that's a personal choice. It's just with the little difference in price it's an inexpensive way to help increase the efficiency of your system.
Just suggestions....
rana is offline   Reply With Quote
inverter, solar
