Old 06-27-2015, 01:14 PM   #1
solar, inverter, and converter
I hooked up some solar panels to keep batteries charged and an inverter for shore-like power. I turned off breakers for AC and microwave, no problem there. Also turned off breaker for converter, this kills half outlets in TT. Is there a purpose for this or can I move converter to separate breaker?
pnbaz is offline   Reply With Quote
Old 06-27-2015, 02:02 PM   #2
fonzie's Avatar
You can move converter to separate breaker, no issues.....
Fonzie
Old 06-27-2015, 02:08 PM   #3
Turning off your converter shouldn't have any impact on any of your outlets. It's a 12v system whereas your outlets are 110vac.
You can move it to a separate breaker... however.. I've never seen a rig that the converter wasn't already on it's own circuit.
If it is indeed impacting your 110vac systems there is something wonky going on there that should be investigated further.
rana is offline   Reply With Quote
converter, inverter, solar
