Old 06-29-2019, 07:21 AM   #1
Solar panel
I was thinking of installing a small solar panel to keep my battery charged between camping trips.
I go every 1 to 2 months.
Option number 2 just unhooking the battery.
Because the battery is dead in about 5 days when the trailer is not plugged in.
Tblt44 is online now   Reply With Quote
Old 06-29-2019, 07:28 AM   #2
Flybob's Avatar
You can add a battery disconnect switch or if you have sun you can add solar. if you add solar I do not recommend anything less than a 40-50W panel and appropriate controller. You will not be happy with the small 10W trickle charge panels.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-29-2019, 07:29 AM   #3
Herowe's Avatar
I bought a cheap little clip on solar panel on eBay for $15.00. It has done the job for 3 years now and we go 6 months between trips at times.
Henry & Cindy
2017 F-350 4X4 Crew Cab Lariat 6.7L Diesel 3.55 Elec Locker Rear
2017 Rockwood Ultra Lite 2902WS
Herowe is offline   Reply With Quote
Old 06-29-2019, 07:32 AM   #4
Can a solar panel over charge it and damage the battery.
Or is keeping it constantly charged better on the battery ?
Old 06-29-2019, 08:28 AM   #5
A32Deuce's Avatar
If it has a good controller, no. I have 2 panels on the roof with a good controller and it keeps them up with out over charging!
A32Deuce is online now   Reply With Quote
Old 06-29-2019, 12:03 PM   #6
Ok I decided just to install a disconnect switch.
Didn't realize I needed a panel and controller
Old 06-29-2019, 12:12 PM   #7
A32Deuce's Avatar
Some panels have a built in controller. Suitcase type I seem to have read on here.
Old 06-29-2019, 03:14 PM   #8
Small panels (less than 40-50 watts may work well in Florida but in areas where sun is more scarce, not so much.
Controllers for simple battery maintenance are plentiful at low prices. For battery maintenance one doesn't necessarily have to buy a "suitcase type" which are typically more for charging batteries while actually camping.
My old, "pre-Lithium" batteries had an internal discharge rate around 1/2 amp or so when disconnected. .5 X 13.25 volt (float voltage of Lead Acid battery) is 6.6 watts. Allow for the fact that "Solar" is only effective around 1/3 of the day and you want to keep up with the internal discharge, then panels of 20 watts or more would work OK.
Just remember, all those small "Battery Maintainer" solar panels in the 5-10 watt range are more for maintaining small batteries, not a bank of deep cycle batteries.
And yes, either turn off existing battery switch or add one so you can disconnect batteries for storage.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
Old 06-30-2019, 10:24 AM   #9
Ok the side of my camper says solar ready
Zamp powered.
Does this mean it has a regulator built in to prevent over charging
Old 06-30-2019, 10:37 AM   #10
Flybob's Avatar
No. That means there is a connector on the trailer and a wire to the battery. Many of the Zamp systems have a controller attached to the panel. The Zamp system uses a reverse polarity standard from most so be sure to test. The Zamp system is quick and easy, but expensive and limited in capability. Also you want the distance from the controller to the battery to be minimal.
TST Tire Monitors
2 100W solar panels
solar, solar panel
