Old 03-13-2015, 07:37 PM   #11
RPAspey's Avatar
They look good. Did you figure a way to tilt them?
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 03-13-2015, 07:46 PM   #12
Blackhat6mike's Avatar
I have 6 x 100 watt Renogy panels and a 40 watt Tracer MPPT controller. They are arranged 3 in series then hooked up in parallel. It keeps the volts up and the amps down as 12 vdc does not like to travel far without losses. Can't believe how much power they provide. I added two more 125 AH batts and haven't wanted for electricity since. They keep the batts at or above 12.8. When I turn something on, it uses the incoming power first, then from the batts if the draw is above what the panels are producing. First thing in the morning at sunrise, they start into boost charge to bring the batts back up. Why I didn't do this years ago, I don't know.
All the panels are mounted with wellnuts and Goop. They are only 3/4 inch above roof, so no wind can get under them. Seagull poop and leaves are my only problems.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-13-2015, 08:08 PM   #13
Hi, no I didn't make them so they could tilt. Just used the supplied Z brackets. My plan is to try the three panels out this summer and if I find that I need more I will add them this fall or next spring. I'm planing to purchase the 100W portable/foldable panels soon in case I park in shade.
Thanks for all the help. The snap toggles are a great idea I just couldn't use them in my application. Good thing I had already purchased the well nuts.
realredrebel is offline   Reply With Quote
Old 03-14-2015, 06:52 AM   #14
RPAspey's Avatar
Keep us updated on how things go. I know I like the updates and so do a lot of others.
Solar is awesome for camping.
Old 03-18-2015, 09:44 PM   #15
Name:	ImageUploadedByForest River Forums1426732846.363425.jpg
ID:	71686Click image for larger version
Name:	ImageUploadedByForest River Forums1426732860.353988.jpg
Finished the solar install. Works great. Next month the inverter.
Old 03-31-2015, 10:21 PM   #16
Alberta8311ss's Avatar
I love the hinge with the removable pin. I need to do this as well.
Alberta8311ss is offline   Reply With Quote
mount, roo, roof, solar
