Old 08-19-2013, 07:40 PM   #1
Rodney Butalla's Avatar
Solar panel mounted to tv mast?
I was wondering if it is possible to replace the tv antenna with a solar panel, that way you could adjust the angel to the sun in accordance with your campsite? Or would the weight of the panel be to much for the plastic gears in there?
Rodney Butalla is offline   Reply With Quote
Old 08-20-2013, 07:04 AM   #2
RPAspey's Avatar
depends....If your panel is bigger than a shoe box then, yes, its too big A small panel is useless. If you get a panel big enough to be useful then you will have problems like weight and surface area. The antenna mast can only lift so much. The surface area is a problem too, when the wind blows you'll have a sail. The mast should have been designed for the wind load based on the surface area of the antenna...any more might be a problem.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 08-20-2013, 05:41 PM   #3
Thanks, it was just a thought, and you confirmed my suspicions!
mount, solar
