Old 08-17-2018, 09:12 PM   #1
rk06382's Avatar
Question Solar panel over sizing with rigid roof mount
I have six 100 watt Renogy panels with a Epever TRIRON 40a MPPT solar charge controller rated for 550 watts. The highest wattage I have seen is 365 watts. That is about 60% of the 600 watts.
I am replacing the 40a MPPT with a Victron 50a SmartSolar MPPT 100/50 Solar Charge Controller with Bluetooth. The Victron 50a MPPT is rated for 700 watts. I plan to add 200 watts more for a total of 800 watts. The theory is the sun will never be 90 degrees to ridge panels mounted on the roof. I can either climb up on the roof to tilt the panels or add panels to get more power. I am too old to climb up on my roof everyday. It is easier to install the extra panels. I will also installed circuit breakers to limit the amperage to and from the solar charge controller.
This the question:
Does anyone else over size their solar panels? If so, please give details.
Thanks,
Robert
2018 FR3 28DS
Samlex EVO-2212 Inverter/Charger | 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 600 Watts Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads
Retired: Alaska Army NG
rk06382 is online now   Reply With Quote
Old 08-17-2018, 09:41 PM   #2
With a PWM controller, that's about right. You get around 5.5A peak with a 100W panel. 6 x 5.5 x 14 = 462W.
People put more panels than the rating all the time. The Victron will limit output to 50A.
2017 Coachmen 233RBS
2018 Ford F150 Lariat
"Common sense is not very common"
babock is offline   Reply With Quote
Old 08-17-2018, 10:24 PM   #3
Hi,
I went to 600 watts of Renogy panels, from 300, for the same reason -- I am too old (and lazy) to get on the roof to tilt panels.
With them, I went two months in Quartzsite this winter in my Silverback, and never had to fire up the backup genny. Lots of DVD and TV when I wanted at night, microwave, coffee machine, all the comforts of home...
FWIW.
Rich Phillips
Rich Phillips
2009 K-2500 Duramax
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 08-17-2018, 10:48 PM   #4
Recently new!
Paulie1138's Avatar
Send a message via AIM to Paulie1138
I didn’t overkill with lot of panels. I went a different approach. I did not use 12v panels. My thinking, in partial shade, they may not produce enough voltage to get the charger up and producing much voltage/current. I mounted mine flat on the roof, with about 2-3 inches vent space between the roof and panels. Made my mounts such that, they can be tilted with minor mods, but...who wants to go up there and fiddle? (I know....there is a play where somebody does....LOL)
I went with 2 full sized commercial 48v panels at 9.9amps each. Running into a Morningstar MPPT controller. That converts 48v to 12v. Side benefit, current goes up by about 4....in theory...and nothing is 100% efficient....but I have purposely ran my batteries to 50%, switched off the charger until I had mostly good sun (was still partially shaded....but not much) turned on the charger, it was blasting out almost 50 amps until it tapered off. Normal operation, by 9-10am, 100% charge. In theory, I can get somewhere around 75 amps on a good day, but I doubt I will ever see that. Also, the controller tops out at 60 amps anyway. Another benefit, I have room for up to 4 more panels. That would allow for a greater output on those dark and gloomy days. Time will tell.
Monitoring of the system and batteries is done with a Trimetric battery monitor.
Bought most everything off Crookslist. Much of the electrical Conduit, boxes, wire, was gifted by contractor friends, so not into the experiment for too much. Because of that, everything is done with #6 ga wiring. Overkill, but free.
Just back from just over 2 months out, only a few of those nights in a campground with electrical. I was able to run everything except the air conditioning. Hence the want to stay in a CG with electric. Never touched the generator, and regretted bringing it. It is only 1000 watts, but took up space, and not big enough for the air. Maybe next outing, bigger genny? More panels? MUCH bigger batteries? Naaaww....LOL!
1987 Starcraft Nova tent trailer, purch. '87, sold 8.14
2013 Crusader 290RLT bought new, 8.14
2001 Ford F-250 7.3
A Loving wife and Mason the always dirty dog!
Paulie1138 is offline   Reply With Quote
Old 08-17-2018, 11:55 PM   #5
You will want to put your panels in a series/parallel config. The Victron MPPT requires 5v over battery voltage to even operate. I run my 4 175W panels in series/parallel to get 40V panel voltage coming in. I have lithium batteries so the voltage is even higher than FLA.
I installed one of these Victron controllers for my brother and it wouldn't even charge with his 2 125W flex panels hooked up in parallel.
With my panels, I run 8 gauge from the panels to a junction box where I make all the series/parallel connections and the 4 gauge down to my controller which is around a 12 foot run. I make sure everything is at most a 3% drop. In most cases, its far below that.
Old 08-18-2018, 12:05 AM   #6
Here is what my setup looks like...no shading! I have one of my panels above one of the vents so I didn't have to mount it next to the AC.
Old 08-18-2018, 12:13 AM   #7
Recently new!
Paulie1138's Avatar
Here is what I did
Here is the rooftop of mine. I ran the wires down thru the roof, inside a wall, to the basement, to the batteries and controller. Hope the pix load.
ID:	183592   Click image for larger version
ID:	183593   Click image for larger version
2001 Ford F-250 7.3
Old 08-18-2018, 12:19 AM   #8
Recently new!
Paulie1138's Avatar
Babock, your pix did not load. Despite the appparent proximity to the air conditioner, shading has not been a problem as there is a bit more space than appears. Even if i get shading, since these are the high voltage panels, they are wired in parallel. I did add blocking diodes to the install to further minimize shading issues. Each panel has its own 2 conductors of #6. Line loss at 48v is negligible. Fully loaded at 9.9 amps, voltage drops to 44 volts, but that is per panel specification, not due to line loss.
From the controller to batteries, #4, about 2.5 feet with a fuse block in the run.
2001 Ford F-250 7.3
Old 08-18-2018, 12:27 AM   #9
How about now?
Old 08-18-2018, 12:32 AM   #10
I'm installing my panels tomorrow with a Victron controller. This is super concerning.
I wanted parallel for shading. Now I can't do that?
aeblank is offline   Reply With Quote
roo, solar panel, roof, mount, solar
