Old 11-10-2015, 01:21 PM   #1
Solar panel placement
Hey all,
I'm researching solar for our new rig (Vengeance 25V)and I think my main concern is that we camp mostly in shaded areas and I'm wondering, can I mount 1 or 2 panels on the roof and have a remote panel on the ground that I can chase the sun with and have them all tied into the system at the same time?
We pretty much just want to use some LED lights, flush the toilet (which means run the water pump), the normal "phantom" draw (fridge, CO2 alarm, etc.) and MAYBE very rarely use the TV. So we're not looking for loads of power.
I know I have LOTS of other questions and issues but need to get the rig 1st and start really planning it out.
Thanks,
John
johnm1 is offline   Reply With Quote
Old 11-11-2015, 12:08 AM   #2
Altestore.com
mfMcFroggierPod is offline   Reply With Quote
Old 11-11-2015, 12:17 AM   #3
Bluepill's Avatar
PV panels that are even partially shadowed will drop their output drastically.
Link:http://www.pveducation.org/pvcdrom/modules/shading
It sounds like your best bet would be a portable panel kit that you could keep in the full sun.
LINK:
http://www.zampsolar.com/rv-solar-ki...ortable-solar/
2008 Itasca Meridian 37H
Old 11-11-2015, 02:21 AM   #4
Yes you can set up your system with a couple panels on the roof and another portable on the ground. The best way to do it is connect them parallel, so you can use just two panels on the roof or connect up your portable panel to the system if needed.
Run the wires from the panels on the roof down the fridge chimmeny/vent and tie in a quick connect connection to the roof wires in behind the removable exterior fridge panel for your portable panel (easy access to connect portable panel).
The proper sized charge controller will operate just fine with 2 panels connected or all 3 connected.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 11-11-2015, 06:48 AM   #5
mud yapster's Avatar
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-11-2015, 10:48 AM   #6
I think you will probably find that having the panels on the roof will be enough and that fooling around with a moveable panel won't yield enough extra to make it worth the trouble. Maybe instead put four panels up top if you have the space. The panels, generally, are not the costliest item. The controllers and install are more. I've always done overkill on the panels and do a real good job of wiring. We have camped in sites where I was sure I wouldn't charge and came home to full batteries every time. That said, I always had at least 500W on the roof and generally more than that. See my blog referenced in the signature for more ideas about how to do this. Mud Yapster is my new hero. His rig looks very solid to me! He has so dang much real estate on his roof I'm thinking of leasing some from him!
There are decent selections of 12V solar panels on Amazon and some have free shipping if you are prime. Shipping will kill you as these things are bulky and odd shaped.
Mud Yapster's system could accommodate high voltage panels that are cheaper per watt as they are more widely used in the rooftop solar industry. They are physically larger so roof space on your rig has to be carefully mapped to ensure they will fit, but cheaper per watt. But you must have an MPPT controller like Mud Yapster has. The cost delta between the Morningstar Tristar MPPT controller and the same amperage PWM controller is $340. That $340 will buy you two more low voltage panels. Do yourself a favor and get one of the Tristars. They are better built and will provide better service to you than a cheaper one.
A long argument for our against MPPT vs. PWM will undoubtedly occur. And both sides of the argument will be technically correct but the difference in a small system will ultimately be trivial but the cost delta is not. Act accordingly. It boils down to a simple arithmetic equation. Sum the cost of the panels and charge controller and divide by watts. Maybe add a little fudge on the MPPT to make you feel better if you decide to go that direction or smile a bit at what you save if you decide to go PWM. You can't really go wrong either way. I've built both and loved both. On my big system I was smug with my MPPT. I had over 1000W on the roof and my batteries were always charged before 10:00AM. On my current rig I have 600W (4 LV panels) and the Bogart Engineering meter and charge controller. My batteries are always charged before noon. And I'm still smug!
I liked what Mud (I've shortened it) had to say about his top amperage output: he only saw that when his batteries were sufficiently discharged to need as many amps as he could get out of his system! I hardly ever see that and wish I did. Then you really know you have a great system.
Keep studying and then build yourself a killer system.
Kelly
Show Low and Rio Verde, AZ
cuernoverdesolar.wordpress.com
Klipstr is offline   Reply With Quote
Old 11-11-2015, 12:14 PM   #7
This is some great info - thanks! Since we don't have the new rig yet I don't know what the roof looks like, which means I don't know what my limitations are for physical size, shape and location of the panels. I'm thinking that's the 1st thing I need to know?
With that said, is there any kind of a guesstimate on how much loss there is in a "dappled" sunlit campsite? Like I said, we camp mainly in NYS and there are LOTS of trees in NYS. Hence the question about trying to chase the sun with a remote panel vs permanent mounting on the roof. Obviously permanent is way easier since I wouldn't have to touch the system after install except for checking the battery water level.
I've also been pondering the age old question of (2) 12v (true) deep cycle batts in parallel or (2) 6v deep cycle batts (like the T-105's) in series. A friend may have just convinced me to look into going the (2) 6v batts and have a 12v "spare" on hand. Probably the one that comes with the rig. The 12v batt would be separated from the charging system via a battery switch and get charged from a trickle/maintenance charger only when plugged into the campground power pole.
Thanks again,
John
Old 11-11-2015, 01:30 PM   #8
I have camped quite often on the west side of Vancouver Island (2-3 weeks in one spot) with big cedar trees shading my campsite. My batterys (pair of 6v) were always charged by early afternoon with 200 watts of solar (roof mounted).
I'm not much of a power hog, so your experience may be different.
2007 Surveyor SV230
Old 11-11-2015, 01:59 PM   #9
KMP44's Avatar
We camp extensively in NYSP's - mostly in the Adirondacks. I bought two 100 watt panels intending to put one on the roof and keep one portable. After a couple trips last year playing around with the portable one, I didn't even bother mounting the second one on the roof. We are now revising our file of favorite sites at the different parks based on "solar friendliness" but camping in the woods is a challenge when trying to generate solar power.
We've found that some sites have an open area in the tree canopy that allows for solar, but frequently there is no way to get the trailer unto the right spot. Portable is the way to go. And the other big advantage to portable is that it is easy to angle the panels. You can easily get 30-40% more output by angling the panels. With 200 watts of panels, we were making 8-10 amps regularly in the spot pictured below. But, I had to move the panels 3 times over the course of the day to keep them in the sun. Just laying them flat in one spot (as they would be on the roof) would only produce 2-3 amps most of the time. Went 5 nights (including one rainy day) with no problem keeping the batteries charged.
Roof mounted is also good for a built in battery maintainer in storage. At the beach or other open areas, roof mounted for sure, but in the woods, I would stay with portable. The one major downside - the panels are fairly heavy & bulky so transporting and setting them up is a pain. But they are useless if you can't get them into the sun. You can always put 20-30 feet of cable on one and try out as a portable. See how it does and then decide if you want to mount it (or mount a couple additional ones).
But the short story is we have been happy keeping them portable and love dry camping without a generator.
2017 F-250
2013 Rockwood Roo 23 IKSS
KMP44 is offline   Reply With Quote
Old 11-11-2015, 02:18 PM   #10
We do most of our camping in the Adirondacks as well and we're conservative with power usage too so maybe portable is the way to go.
solar, solar panel
