Old 11-17-2019, 11:21 AM   #1
Solar panels and interference w/ ham radio
I have been using 2 panels of 100W ea as portables on the ground with no problems, and now I want to mount them on my 5er roof permanently. I have a screwdriver antenna and of course other antennas up top. Have any of you experienced interference to ham radio, TV, sound systems, etc?
2011 Sabre Silhouette 260BHS
2006 F-250 6.OL
tinkerreknit is offline   Reply With Quote
Old 11-17-2019, 12:51 PM   #2
WoodLark-SC's Avatar
The panels themselves shouldn't cause any interference. The controller might if it is located close to your antenna.
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
WoodLark-SC is offline   Reply With Quote
Old 11-17-2019, 01:02 PM   #3
Thanks for your help. The controller is in the front storage area next to the batteries. It's been in that location all along, when the panels were on the ground. No problems then.
2006 F-250 6.OL
Old 11-17-2019, 01:39 PM   #4
No problem. You are good to go, the panels do not produce any RF.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 11-17-2019, 03:45 PM   #5
NXR
NXR's Avatar
Unless the run of wires to the panels is shielded, I'd haul the radio outside, stick a wire in the antenna jack and put the wire near the controller. Actually, I'd do it either way. If the wiring is not shielded I'd consider buying some ferrite beads and putting them on the solar panel wires at the controller for good measure, especially if you're thinking about running higher power HF.
What bands are you looking to run?
If you're looking to buy yourself a Christmas gift, check this out: https://www.amazon.com/RF-Explorer-W...=5748416080301
50 KHz to 960 MHz for under $200: https://j3.rf-explorer.com/menu-the-...s-50khz-960mhz
I have both the older non-slim model and the 6G Combo model.
Ray
2020 Georgetown GT5 34H5
NXR is offline   Reply With Quote
Old 11-17-2019, 03:51 PM   #6
Curious, why would he need shielded wires from the panels to controller?
2007 Surveyor SV230
Old 11-17-2019, 04:55 PM   #7
NXR is probably concerned about my radio sending voltage through my solar wiring down to the controller and damaging it. I can check for RF prior to connecting to the controller. I can transmit 100W, and I can be anywhere from 6 meters to 20 meters.
2006 F-250 6.OL
Old 11-17-2019, 05:13 PM   #8
Thanks tinkerreknit, that could be possible.
2007 Surveyor SV230
Old 11-17-2019, 05:57 PM   #9
NXR
NXR's Avatar
Yup, both ways, actually. If the controller is generating low level broadband noise it could send it up the new solar panel wiring where the wiring would act as an antenna and give him a noise problem he did not have before.
That assumes that the new wiring actually would be longer than the current portable panels, of course.
I actually just put my Xeigu X108G 15-watt HF radio and the SuperAntenna in the motorhome today for our winter trip. This is our first time so I'm not sure how well it will work out in an RV park. I'll probably bring the CW key along because that should work better with low power. This setup actually worked pretty well on 40 and 20 during Field Day.
Ray
Old 11-18-2019, 09:03 AM   #10
Our family has camped with solar and operated HF without any problems. We have a 470W system (2x235W panels) and use a Morningstar Tristar MPPT controller charging 4 6-volt golf cart batteries. Our camping radio is a Kenwood TS-480SAT feeding a dipole antenna. We ran 100 watts and operated 15, 17, 20 and 40m bands. I am very happy with our setup as it's been both reliable and quiet.
Dave in SK
VE5DLC
Trailer: 2011 Cedar Creek Silverback 35K
Truck: 2006 Dodge 2500 TRX4 Cummins
Seasonal at Saskatchewan Landing Provincial Park
camaro80 is offline   Reply With Quote
Old 11-18-2019, 01:38 PM   #11
Ham Radio and Solar Panels
Solar panels output up to 21V DC , DC or direct currant does not cause interference because there is no sine wave or pulsing.
There are 2 basic types of solar controllers: SHUNT and a type of Pulse Width Modulation .
SHUNT controllers are a linear system that does not create pulses to interfere
Other types will use pulsed (digital) as part of their regulating circuits and can generator very strong signals at multiples of the regulators operating frequency, say 50,000 hertz to 100,000 hertz and many multiples higher therefore causing SEVERE noisy inference for long distances at certain radio frequencies.
High Frequency communications, 1-30 megahertz and maybe 50 megahertz can be affected especially by cheap battery chargers and non shunt type regulators.
VHF, UHF and above will not be affected so to say ďham radioĒ a person has to be more specific, HF, VHF or UHF ??
A generous application of Low Frequency Ferrite cores to block electro magnetic interference often works.
My Sunseeker with 60 watt solar panel on the roof and controller near the house batteries has NO interference from 1 to 450 Mhz. Have fun ......
bbillp is offline   Reply With Quote
Old 11-18-2019, 08:57 PM   #12
I have had very good luck with a MPPT control. The bead advise is good. I would try to see what changed and see if the noise goes away night. 73
n0ms is offline   Reply With Quote
Old 11-18-2019, 10:06 PM   #13
tomfmcs's Avatar
I have had no issue with solar and rfi. work hf/vhf/uhf a lot of it is boon docking.
N2IWU/Colorado
tomfmcs is offline   Reply With Quote
Old 11-19-2019, 06:06 PM   #14
Thanks guys, for the feedback! It's reassuring. I had read some stuff about interference and was concerned. I really like my panels on the ground so that I can chase the sun and tilt and turn often. But it is a handful getting the panels out, connecting them, and securing them with padlocks. I won't be anywhere near as efficient with them mounted on top. I might even get a 3rd panel, later on, to keep as a portable. I still have a ways to go to find time to mount the panels and test things out.
2006 F-250 6.OL
radio, solar, solar panel
