Old 03-27-2016, 01:18 PM   #11
Rmusson, not over kill, sounds like a very secure install. Happy Camping.
Rich5117 is offline   Reply With Quote
Old 03-27-2016, 06:25 PM   #12
RailwayRog
Originally Posted by nodrawers View Post
Too scary for me so I went portable panels with Trimetric SC2030 controller & TM2030 monitor permanently. Mounted with quick disconnect for panels works great and I still get to park in the shade. Takes less than 5 min to set up.
Initially I was going to go this way but I thought about storage space and I basically wanted to forget about them, BUT, had I known what I now know I would go this way.
I also went with the Trimetric SC2030 and TM2030.
I did a lot of research in to controllers and with the help of https://handybobsolar.wordpress.com/ I was able feel money was well spent and beside Ralph at Bogart Engineering (the maker of Trimetric home - Bogart Engineering) answered my questions right away.
I kinda like what Randman did with flexible panel where as the air can't pick the panel up and lift it off the roof. But I'm wondering since no air moves under the panel whether the high temps. affect it adversely as far as output.
RailwayRog is offline   Reply With Quote
Old 03-27-2016, 09:06 PM   #13
Too Tall's Avatar
That's a really nice setup, can i ask how much you have invested in the panels and controller etc...?
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 03-27-2016, 09:09 PM   #14
Too Tall's Avatar
Originally Posted by RailwayRog View Post
What size toggle bolts did you guys use?
I used the smallest I kind find, 1/8, I wanted to keep the hole in roof to a minimum and I only used one per bracket (there are two mounting holes per bracket).
I used 1/4" on the inside wall but I'm one of those "Too strong never failed" fanatics.
USMC 68 -70
Old 03-27-2016, 09:12 PM   #15
Blackhat6mike's Avatar
Try the Renogy website. They have all you need. No problems in my system in over two years and it didn't break the bank. You can put together a 200 watt system with MPPT controller, MT-5 monitor, wiring and fuse for under $500. Stick with the MPPT controller and stay away from the PWM unit. Big difference. Been there and done that.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 03-27-2016, 09:35 PM   #16
Too Tall's Avatar
Thanks, i'll check it out. I don't want a permanent mounted panel, want to it to be portable.
USMC 68 -70
Old 03-27-2016, 09:56 PM   #17
I have the exact setup. Spent about $750 for panels, controller, monitor, wires, etc. We store the panels behind the couch when traveling. The charge controller and Trimetric battery monitor are mounted in a Torklift aluminum battery box. The box is big enough for 4 batteries but I divided it in half. (There is a gasket around the divider to keep battery gases away from the controller)
I am going to mount a third panel on the roof to keep the batteries charged. I think I might use angle aluminum strips, as previously mentioned, for a more secure mount.
2015 Solaire 201SS
2015 GMC 2500HD Duramax
PSU Turf is offline   Reply With Quote
Old 03-27-2016, 10:14 PM   #18
Too Tall's Avatar
About how much do you estimate this system weights? I'm pretty limited on GVRW but I can carry a bunch in the truck.
USMC 68 -70
Old 03-27-2016, 10:18 PM   #19
I think the panels are about 16 lbs each. Wire, controller, monitor might add 10 lbs at most.
2015 Solaire 201SS
Old 03-27-2016, 10:51 PM   #20
Sorry, can't help with portable solar. I wanted a system that I could install and forget about it and not have something else to setup and take down every time we moved. Got enough to do already.
roo, roof, solar, solar panel
