Old 08-07-2017, 09:26 PM   #1
Scoundrel
HangDiver's Avatar
Solar Panels On Rubber Roof
I've searched and subscribed to numerous threads but have not found answers to this question? How are you mounting your RIGID solar panels to rubber roofs?
Thanks in advance,
Rich J.
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 08-08-2017, 05:48 AM   #2
Hi,
Aluminum brackets, lag screws, and Dicor.
Rich Phillips
richp is online now   Reply With Quote
Old 08-08-2017, 10:13 AM   #3
Aluminum brackets, stainless sheet metal screws and Dicor.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 08-08-2017, 10:18 AM   #4
Scoundrel
HangDiver's Avatar
Thank you for the replies. I was debating between lag screws or well nuts. Seems I'll be using lag screws.
Thanks again,
Rich J.
Old 08-08-2017, 12:36 PM   #5
MilCop4523's Avatar
https://www.ebay.com/p/4x-Corner-2x-...r=531463143348
better than metal brackets i'm told.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
Old 08-08-2017, 01:16 PM   #6
RB19RR is offline   Reply With Quote
Old 08-08-2017, 02:01 PM   #7
Just getting ready to install 2 panels myself. I will use Stainless steel 3/4 " screws into z brackets. I will use 2 brackets on each side and one on each end = 6 brackets on each panel. Self leveling horizontal sealant .
Roof prep cleaning needed.
Dpelaez is offline   Reply With Quote
Old 08-08-2017, 02:37 PM   #8
Hi,
I just left the Dicor roof presentation at the Rally.
He recommended using a pad of butyl tape between solar brackets and the roof, before tightening everything down and covering with Dicor.
FWIW.
Rich Phillips
Old 08-08-2017, 02:42 PM   #9
Scoundrel
HangDiver's Avatar
Originally Posted by richp View Post
Hi,
Rich Phillips
That makes good sense. Thank you Rich!
Old 08-08-2017, 02:50 PM   #10
I agree and have already applied the butyl tape to the bottom of the bracmet but forgot to mention.
roo, roof, solar, solar panel
