Old 05-29-2016, 09:28 AM   #1
Real Nice Clark
Solar panels over-charging?
First trip out with my Zamp solar panel. My TT has the pre-wired Zamp connection. It seems to work great and charges my 2 12V (group 24) batteries fairly quickly. Question though: checked the controller yesterday it was showing 14.7 volts from the battery bank and was still showing to be in absorption/equalization charging mode. I thought it should go into float charging after reaching 13.6V? I unplugged it at that point. Now, reading the specifications for the solar controller, it shows "absorption charging voltage at 25*C-14.7". But it also reads "float charging at 25*C- 13.6". Am I correct in thinking it should have gone into float charging after reaching 13.6V? Could it have damaged the batteries getting up to 14.7?
mountainjunkie is offline   Reply With Quote
Old 05-29-2016, 09:45 AM   #2
WolfWhistle's Avatar
Not sure what the 25*C means (do you have temperature probe) but the charger should remain in absorb (14.7 is good, but I like 14.8 better) for about 1-1/2 hours after reaching 100%; then drop to float. Keep in mind it is reading battery voltage while under charge so it will be high. If you get a chance, let the batteries rest (no load and no charge for several hours and read them.. should be truly full at 12.7 vdc, but more importantly the specific gravity should read 1.265. So, it is normal and good to remain in absorb beyond "full", time wise. You will not boil the batteries, as some claim. Do, however, check water on a routine basis.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 05-29-2016, 09:48 AM   #3
Real Nice Clark
thanks!
Old 06-02-2016, 07:55 PM   #4
25*C I'll guess is 25 degrees Celcius (77*F)... Most controllers will give a temperature and a voltage rating for a reference.. As WW mentioned your batteries won't boil, unless you've had it on the absorption level for a couple of days or more, which would indicate a failed controller..
Camped: 2017 (Days/Nights) - 30/25
2016 (Days/Nights) - 32/23, 2015 Nights - 29
TT: 2013 26' Revere TBQB
TV: 2014 GMC Sierra 1500 Z71 4x4
glen1971 is offline   Reply With Quote
Old 06-02-2016, 10:51 PM   #5
Real Nice Clark
Now that I realized it was normal to get that high for a short period everything seemed to be in order.
charging, solar, solar panel
