Old 07-13-2019, 06:36 PM   #1
tmlogo's Avatar
Solar Powered Generator
We have yet to buy generators for our Mini lite 2104s. Recently a friend told us of a generator they bought at Costco that runs on solar. Wondering if anyone has experience with this type of generator, and do they work well? Any brand recommendations?.
tmlogo is offline   Reply With Quote
Old 07-13-2019, 07:42 PM   #2
Flybob's Avatar
Something doesn't sound right here. There are systems that generate power using solar as a source and a controller for DC and inverter for AC, but this is different than a generator. Please ask your friend for details, link, manufacturer. There are some small solar/battery gizmos that are marketed as a generator, but that all it is is marketing.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-13-2019, 07:51 PM   #3
wmtire's Avatar
Yeah, what these are is a battery powered inverter, recharged by solar.
They do call them generators, and they do produce 120 volt AC.
https://www.costco.com/Goal-Zero-Yet...100338966.html
https://www.amazon.com/slp/portable-...987yrm9t4u85xf
2011 Flagstaff 831 RLBSS
Old 07-13-2019, 09:24 PM   #4
Hi,
Gimmick nomenclature with variations on this theme...
A relatively small battery, a small inverter, and some outlets in a case -- ready for solar input but nowhere capable of powering anything of substance for any lengthy period of time.
Good for a very limited array of uses, in my view.
FWIW.
Rich Phillips
Rich Phillips
2019 K-2500 Duramax Crew Cab
2014 Silverback 33RL
richp is offline   Reply With Quote
Old 07-13-2019, 09:38 PM   #5
Already wired for solar panel
Your Mini Lite is already wired for a portable solar panel, with the plug right there by the forward passenger side storage bin door. All you need is a 100 watt solar panel WITH the charger controller and your set for boondocking. However, if you're wanting to run big things like your AC, you will need a pretty decent sized typical gasoline motor powered generator, that would be rated for probably 2000 watts output.
https://www.amazon.com/Renogy-Monocr...s%2C134&sr=8-3
McKannick is offline   Reply With Quote
Old 07-13-2019, 10:31 PM   #6
Lets go camping!
str8t six's Avatar
yup, your friend basically purchased a battery with a inverter.
2014 Rockwood Mini Lite 2504s
2016 Ram 3500
str8t six is offline   Reply With Quote
Old 07-14-2019, 12:46 AM   #7
bikendan's Avatar
The only things those are good for, is charging electronic devices and power some lights.
Old 07-14-2019, 01:34 PM   #8
If I read all the ad's correctly they seem to be directed more toward Tent Campers to do just what you stated.
Compact, easy to store and transport in a trunk, SUV, or "Station Wagon".
I have run across some that are the size of a backyard bbq that have more battery capacity and a somewhat intricate system of folding panels that can be deployed at site. Price was rather high and probably used Lithium batteries. Wasn't interested so I didn't pursue specs, etc.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
generator, power, solar
