Old 04-13-2016, 04:34 AM   #11
Justice12t's Avatar
Originally Posted by Blackhat6mike View Post
IMHO, 2 x 6vdc batteries isn't enough storage. You might want to consider more elec storage.
Thanks for the info. I certainly don't disagree. We are going to start small and build from there. If I need 2 more batteries or more solar than I will get it. We don't boondocks a lot but would like to do more.
2016 Prime Time Crusader 294RLT
2016 Days Camped - 31
2017 Camping Blues - ...
Justice12t is offline   Reply With Quote
Old 04-13-2016, 04:53 AM   #12
World Wide Wanderer
wahoonc's Avatar
Originally Posted by silver View Post
I did a lot of research last year and ended up at Renogy | The Future of Clean Energy. They have packages that make the solar end of your equation much more reasonable. Different range of kits from entry level to premium. You may want to check them out.
Renogy would be my first choice. They make complete kits with quality components at competitive prices. I have one of their 100 watt suitcase kits and have been very pleased. When I go permanent mount it will be one of theirs. Make sure you size your battery bank for the intended daily load plus a few more to allow for cloudy or rainy days.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 04-13-2016, 08:10 AM   #13
Thanks for all the info. I talk to Renogy last night and feel pretty good about the set up they quoted me. It was in the $1000+/- range for a complete 200W (2 x 100) panel set up with the 60 amp charge controller so I can add to it later if needed ... which I think I probably will. If nothing else because we'll end up using more electrical stuff 'cause we can :-)
Now I just need to find out about the solar rebates and hopefully pull the trigger on the order.
John M
2013 GMC Sierra 2500DH CC, 4x4, D/A
2016 Forest River Vengeance 25V TT/TH
johnm1 is offline   Reply With Quote
Old 04-13-2016, 01:19 PM   #14
I plan to get solar but right now I can't afford it, I have 2 2000i Honda's that I plan to use on this long trip plus a bank of batteries. I'll be alright on this trip, about 4 months. Next year I plan to install solar, start with two and add more as I can afford it.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 04-13-2016, 02:19 PM   #15
Ok - I've lost the link that I had to the spreadsheet for battery & solar sizing calculator. I also can't find it in a search.
Anyone have a good one?
John M
Old 04-13-2016, 07:25 PM   #16
PokerDealer's Avatar
Just wanted to add, by adding a battery monitor (Trimetric 2030) within a few trips you'll be able to tell for sure how much usage you have. There is an old saying to figure out how many watts of panels you need and double it. Using a good monitor will allow you to zero in on how much you will need. Windy Nation is a good site for off the grid equipment. With power, cheap is not always a good thing, unless you are getting top of the line equipment at a reasonable price.
test have shown you can add 20 to 25% efficiency by pointing your panels. Maximizing your efficiency and monitoring your power collection at least for the 1st 6 months will give you lots of information and peace of mind....
2015 Wildwood 181 BHXL. 2005 1500 Ram Hemi 4x4 W/package
PokerDealer is offline   Reply With Quote
solar
