The biggest thing you need to know is how a solar system basically works. The inverter pulls its power from the 12volt batteries and inverts it to from DC to AC. The solar panels recharge the batteries.
It can take a while to put the charge back into the batteries through solar. So, if you are going to run heavy wattage AC appliances then you need a larger battery bank if you are going to run those appliances for longer periods of time. Likewise if you have a larger battery bank you will need more solar panels to get closer to fully charging those batteries in one day of daylight.
Michael and Pamela
Colorado Springs, CO
2017 Roo 233s
Towed by 2016 Ford F-150 screw, ecoboost, maxtow
Replaced 2011 Ford F-150 screw, ecoboost, maxtow
that overheated every time it towed up hill.
