Old 03-10-2014, 01:45 AM   #11
Yes, (4) 6v batterys with 270 watts of solar should work quite well for you unless you are a real power hog.
Those panels are rated at 18 volts max output. Mine are also, but I have seen them go as high as 24V (in direct sun) which will give you even more amps in the end.
With 270 watts of solar @ 18 volts and a MPPT controller you should be able to harvest on average around 18-20 amps on a sunny day. So 5-6 hours (peak time) x 18-20 amps would feed your batterys at least 90-120 amp hours in a day maybe more.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 03-10-2014, 04:58 AM   #12
Witch Doctor's Avatar
Originally Posted by blissman20 View Post
Thanks so much, I just need to talk to the dealer and see if there I'd anyway for me to retain my roof warranty after drilling holes in it lol
I wouldn't ask my dealer, I would call FR direct and ask them. They are the one's who would have okay the warranty not your dealer.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-10-2014, 09:23 AM   #13
I might have a aftermarket warranty on it as well as the factory, one of those warranties where if you don't make a claim you get a percentage of it back. I believe I have one of those. I wonder if I paid my dealer to install the panels if they would still honor it. Never hurts to as Forest river and my dealer. I know my dealer sells the go power kits and they aren't cheap or else I'd buy from them.
blissman20 is offline   Reply With Quote
Old 03-10-2014, 10:44 AM   #14
After market or not, The third party will not honor the warranty because it is still warranty under FR. I still would call FR. Better to be safe then sorry....
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-10-2014, 10:56 AM   #15
Yeah I'll give them a call in the bear future before drilling any holes
Old 03-11-2014, 12:09 PM   #16
I talked to the company that makes the solar panels and they said that the panels are made of tempered glass and is very Resistant to hail and falling branches.
They also said for best results have them pointed south at 30-40 degree angle
Old 03-11-2014, 01:00 PM   #17
This is true, but would be bad for travel IMO. I would add a device that you would be able to move to that degree. Wouldn't be hard to do or design. I know that I had that on my sail boat, but it was automatic and keep the panels at the correct position as the sun moved. But that solar keep my battery bank up, and eveything ran off of 12v. Except my Ham Radio, and radar is why a inverter was added. They ran separate circuits for that. I had 6 battery installed golf cart size T8 If I remember. Also had a 150 amp alternator incase they where not putting enough power out to keep things running only had a 50 gal diesel tank, but carried 6-10 gal jerry cans, sometime I wouldn't see a shore line for weeks. But the engine only burned 1 and 1/2 gals per hour. 50 hp. @ 6.5 kts.
Coachmen M/H
Concord
2018 / 300 DSC
Old 03-11-2014, 02:54 PM   #18
Sounds like you have a great set up. I might try to build brackets that will adjust angle each way because we camp in two different spots and our trailers position with the sun will be different for each
Old 03-11-2014, 07:28 PM   #19
I was at costco today and saw these batteries, would 4 of them be good?
Old 03-11-2014, 08:15 PM   #20
CZNEDY's Avatar
I installed the 160 watt kit from go-power. Solar panel, cables and charger. Mounted it on the roof, ran the cables down the refridgerator chimney and mounted the charger/controller right above the fridge. Ran the wires from the panels, to the charger and then down to the DC terminals on the converter. We only have the 12V batter that came with the camper and it works good fr the weekends. Have not tested it out to see how long we can go without running the battery down yet. Pictures of the install below.
2018 BERKSHIRE 34QS
2004 Jeep Wrangler and a
Cooler full of good ideas
Days Camped, Not Enough
CZNEDY is online now   Reply With Quote
solar
