Old 12-02-2015, 08:52 AM   #21
Toothpick's Avatar
Never mind I think I found the answer to my question... If I use 4 100 watt panels looks like I'll need at least a 40 amp controller....
2016 FR Vengeance 25V Toy Hauler
2015 Ram 2500HD CC 4x4 6.7L Cummins
2017 Indian Chieftain Darkhorse
2017 Indian Scout
Toothpick is offline   Reply With Quote
Old 12-02-2015, 08:56 AM   #22
Originally Posted by mele View Post
Ok.... Now if I want to upgrade will a 20 amp mppt controller be large enough for 4 100 watt panels in a series-parallel?
NO
12v 100W = 8.33333 amps x4 33.3333 amps
thats best case, you will get less but you need at least a 30 amp controller
2015 grey wolf 27RR
2015 Chevy 3500HD
kcmusa is offline   Reply With Quote
Old 12-02-2015, 12:14 PM   #23
WolfWhistle's Avatar
Before planning anything regarding solar charging, the first thing to do is to determine how many watts are going to be used and thus how many has to be put back into the batteries. To be talking 100W... 200W... 400W panels first is backward thinking.
First thing is to get and install is a Trimetric battery monitor. Get those numbers and plan properly.
I would suggest getting informed and this is an excellent source for information. WW
https://handybobsolar.wordpress.com/...ging-puzzle-2/
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 12-04-2015, 09:45 AM   #24
Toothpick's Avatar
Thanks, I know.
I'm just thinking out loud on the forum about upgrading later. IF I decide to go from just a battery maintenance setup to full off the grid for my TH.
Mel
2017 Indian Scout
Old 12-05-2015, 01:41 PM   #25
Toothpick's Avatar
Starter Kit came in today. Now to got hook it up!
2017 Indian Scout
Old 12-06-2015, 05:59 PM   #26
Toothpick's Avatar
OK.
My test results from today. Tested with a hand held voltage meter.
My TH is currently on the north side of a strip of Live Oak Trees.
I got from 12.2 to 12.4 volts in direct diffused sunlight (real bright overcast/high clouds) or diffused shade (no real dark shadows sun broken up by high near leafless trees).
I got 12.5 - 12.6 volts sitting on the tailgate of my truck (white) in same general area. So reflected bright light seemed to increase voltage a little. Maybe the white roof on TH will help?
Think I'm going to order a 30A Mppt Controller and two more panels.
If I install them in Series and get near 36V I should have enough juice to keep two group 24 batteries up during the week and run lights, TV and heater on the weekend...
Thanks for everyone's input.
Mel
2017 Indian Scout
Old 12-07-2015, 04:01 PM   #27
OK.
Mel
12 volt panels go in parallel to match the 12 volt charger controller and batteries you have. Not sure how you are measuring them, but if properly tilted they should give you more on a sunny day. Like I said way back, you cannot have any shadow fall on a panel or it will basically give you nothing. You need to study more on solar but in the meantime don't connect panels in series. WW
WW
Old 12-07-2015, 04:44 PM   #28
If you are getting an MPPT controller you can connect the panels in series up to the maximum input voltage of the controller.
The one adavantage to connecting in parallel is if a panel is in shade it will not bring down the voltage as much compared to being connected in series.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 12-07-2015, 09:50 PM   #29
The combined battery voltage has to be up as well ... not to mention appliances, pumps, lights etc etc. The higher DC voltage setups are for other than RVs. IMO
WW
Old 12-07-2015, 09:54 PM   #30
I wouldn't waste my money on an MPPT controller... for an RV
solar
