Old 06-28-2019, 11:20 AM   #1
Solar trickle charging battery
So I looked through other topics and could find what I was looking for, so here goes...
We store our travel trailer off site. It has plenty of sun access (another subject) and today I remove the battery and bring it home and put it on a little trickle charger. Our new trailer (Rockwood 2909) has a solar plug built on and I am wondering if I can just put a 10 watt panel with a charge controller and mount it on the trailer and let it keep the battery juiced? Iíd like to do something instead of removing the battery all time. Any suggestions would be great.
Thanks - Karl
2018 Forest River Rockwood 2909WSD
2018 F150 XLT SCrew MaxTow 20"
karlrmac is offline   Reply With Quote
Old 06-28-2019, 11:32 AM   #2
Flybob's Avatar
You can add a charge controller and a solar panel to keep the battery charged, but I would not use anything less than about 50W panel. A ten watt panel will not keep up with the parasitic draw from the always on items. My recommendation is if you think you will ever use the solar for more than storage to buy a larger controller up front. This way you just need to add panels and probably upgrade the wiring.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-28-2019, 01:04 PM   #3
Flybob, if I flip the switch to kill all power going into the trailer from the battery, would the 10watt panel be sufficient to trickle the battery?
battery, charging, solar
