Old 06-13-2016, 04:09 PM   #11
Woa.... thanks for the multitude of answers....
I guess i am just at the same point i was... lol.
I have the Cat CJ3000. It as a 12 V DC 5 Amp accesory outlet (Cig. Lighter connection) and that is what i intended to use to connect to the Zamp Plug.
Yes, it's true, we use the heater a lot and the pump may run during the same time, but the fridge is not 12V, it runs on gas or 110V only.
I wonder tho how many amps will be drawn from the booster pack, wouldn't it be just half since it's in paralele with the main battery?
I might just make a wire myself going to the battery because my issue is the propane line that runs just over the battery up to the tank, everytime i remove the battery cover i have to move the line out of the way and the first year i got a leak on it because i was removing the battery cover on every trip.
Anyways, i will wait for more feedback with that extra info i just provided before doing anything.
Thanks all.
Stephane, computer tech.
2015 Coachmen Clipper 17BH 50th Anniversary.
Fun Box is offline   Reply With Quote
Old 06-13-2016, 04:24 PM   #12
Another option is to wire up a simple PVC electrical box with some 12V battery jumper posts connected to your RV battery. Then just hook up the jump pack to that. Use some 8 ga wire and run it inside a plastic wire loom. Any 4" grey box from Home Depot would work.
Maybe something like these:
https://www.amazon.com/Allstar-Perfo...EWKKRCW9MVASMN
2001 Ford F250 7.3l converted to F350 specs
2014 Flagstaff 8528RKWS
2 - 2006 model year Border Collies
Mtelkman is offline   Reply With Quote
Old 06-13-2016, 04:25 PM   #13
Who Dares, Wins
doc73's Avatar
How about just adding another battery..
Sent from my SM-G930V using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 06-13-2016, 08:50 PM   #14
I thought about that originaly, but then my wife wanted a bike rack and since you can't have anything but the spare tire on the rear bumper, the extra battery space had to give for the front side bike rack.
Old 06-13-2016, 08:53 PM   #15
I might do just that, but from the inside of the RV, then i don't have to leave the booster pack outside under the RV.
Do the wires from the battery go directly to the electrical box or something like that? All i need is extra wires that go to the same place.
I wonder if there is a wiring diagram for the Clipper 17BH?
solar
