Old 06-19-2013, 08:26 PM   #1
Solera 2013
Bought a new Solera in MI and drove to Fl and the air does not work with the generator running but other electrical does. This the 1st time trying it. The air did work when plugged in at campsite. Help
Goat_7 is offline   Reply With Quote
Old 06-19-2013, 08:30 PM   #2
papap's Avatar
110 volt
Are you sure the 110 volt stuff is working? The light are 12volt.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 06-19-2013, 08:41 PM   #3
Yes the tv outlet is 110 and only will come on if generator is on or plugged in
Old 06-19-2013, 08:44 PM   #4
Yes tv outlet will only work with generator or 110
Old 06-19-2013, 09:05 PM   #5
Taylorgso's Avatar
stock television that comes with the Solera is a 12 Volt. Check your breakers/fuses.
Ed (N4RWU) & Becky Taylor
Mistie (Walks 4-down)
Greensboro, NC
Taylorgso is offline   Reply With Quote
Old 06-19-2013, 09:34 PM   #6
Not stock tv is 110
Old 06-20-2013, 02:15 PM   #7
What generator do you have?I have a Honda 3000,I have to have the eco switch in the off position on the gen,the a/c fan must be set to low so it runs all the time.My a/c is a 13500 btu unit.
09grizzly1
2012 Palomino Ultralite T245
2004 F250 Supercab 5.4L
09 Grizzly 700 EPS
09grizzly1 is offline   Reply With Quote
Old 06-22-2013, 04:48 AM   #8
Took all the fuses out and checked them reset the breakers and checked the converter. It's now working! Thanks
