Old 09-05-2012, 01:43 PM   #1
(Solved) 12V Problems With 2010 Cedar Creek
I have a 2010 Silverback and I am getting no 12v appliances, lights, etc. to work unless hooked to shore power. I replaced the battery with a new one and still no 12v. Also, I have no 12v even when hooked to the truck. When hooked to the shore power I have all working! I checked the fuses in the converter and they are good, also checked the inline fuses and they are good.
rt2439 is offline   Reply With Quote
Old 09-05-2012, 01:53 PM   #2
wmtire's Avatar
Have you noticed/checked an inline fuse or resettable circuit breaker located near the battery?
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 09-05-2012, 01:55 PM   #3
I checked the fuse, but not a circuit breaker. I will check that as well.
Old 09-05-2012, 02:10 PM   #4
wmtire's Avatar
Another question. Do you have any kind of battery cut-off/disconnect switch installed?
With no power getting from your trailer battery/tow vehicle, you won't have electric brakes...so you don't want to pull it anywhere if not needed till this problem is solved.
Old 09-10-2012, 07:21 AM   #5
Problem Solved!! It was the main circuit breaker! Reset it and all works!
Thanks for the help!!
Old 09-10-2012, 07:44 AM   #6
TURBS's Avatar
Saweet ! Love the good outcomes !
12 Volt
