Old 07-31-2012, 08:37 PM   #1
(SOLVED) electrician hooked TT up to 220
Hi guys, I am hoping like crazy that you can help me. I just picked up my new Surveyor TT two weeks ago. This past Friday I had an electrician come over and wire up a 30 amp outlet for me so I could plut the TT in and use the AC and when he hooked it up, smoke started coming out from underneath where the breakers and fuses are.
He finally figured out of course that its 110. After he changed that, I tried the AC, fridge, slide and power awnings and they were working. I just went out to turn on the fridge so it would be good and cold for us to leave this weekend and nothing works. No lights, no slide, no awning, no microwave, no fridge (even on gas) and no AC.
Can you tell me what to do now? This is my first TT and I'm devastated if he did some major damage to it. Also guessing I'm not going anywhere this weekend. One of the reasons I bought a new TT was so that I wouldn't have issues like this. I'm a female and not mechanically inclined and my 78 yr. old mom and I were getting ready to go on a trip. I'm just so upset I can't even think now. I would sure appreciate any advice you have. Thanks.
marcusfan is offline   Reply With Quote
Old 07-31-2012, 08:47 PM   #2
bob213's Avatar
If he wired you up to 220V, I'm afraid you might have fried everything electrical in your trailer. Hopefully it's just the converter but unfortunately it's usually worse. You will have to have the dealer check everything out, report it to your insurance and try to get the electrician to pay up. Sorry to hear about this. I know you've been looking forward to getting out and using your new trailer. I hope it all works out for you.
bob213 is offline   Reply With Quote
Old 07-31-2012, 08:48 PM   #3
Terier's Avatar
From one gal to another I would take it to the dealership and have the service department check it out. I know there are a lot of people out there that can check and fix things but I have yet to find one when I need help. Case point: think of your electrican and how that worked out for you.
  • RV dealerships know RVs
  • Service dept. has experience ordering RV parts and fixing RVs
Old 07-31-2012, 08:49 PM   #4
I was afraid of that. But does it make sense that after he did that, and hooked it up correctly, everything worked? And now a few days later nothing works?
Old 07-31-2012, 08:49 PM   #5
Alleged curmudgeon
Vern's Avatar
Search the forum for a thread entitled "Power converter issue" originally posted by Old Car. Same thing happened to him and the process of evaluation and repair is outlined.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 07-31-2012, 09:02 PM   #6
Old car's Avatar
Sorry to hear about your troubles. I just went through it. I am not an electrician but my guess is a few things may have worked right after the incident because you still had power from your battery. I had to have my power unit, television, microwave, and surround sound stereo entertainment center replaced. Luckily the fridge, air, furnace, and water heater were saved. My insurance covered it (less deductible) and I just got my TT back this past weekend. It's a heartbreaking feeling but luckily no one got hurt and material things can be replaced.
I would talk with the electrician. If he doesn't cover it, check with his insurance. Use yours as a last resort. My mistake; plugging into 220; unfortunately involved my father as the electrician and he really feels bad about what happened. Good luck and feel free to contact me is you wish.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 07-31-2012, 09:53 PM   #7
VinceU's Avatar
It happens because the outlet for RV 30 amp closely resembles the household dryer 30 amp standard. They aren't exact but people mistake the identity on first view. It happens more than you'd think. Its strange things would work at first not later. Most items fed with 2X voltage are damaged at once. If circuit breakers for any ac devices were open, they would have survived. DC loads should all be ok after the converter is repaired. Suspect the lights and reefer controls all quit working after the batteries died. With no charge and some things left on a few days is all it would take to kill the batteries. If in doubt, DC loads all have fuses protecting them. All AC devices have a circuit breaker. Hope for a speedy recovery!
Old 08-01-2012, 12:37 AM   #8
Terier's Avatar
Originally Posted by Terier View Post
From one gal to another I would take it to the dealership and have the service department check it out. I know there are a lot of people out there that can check and fix things but I have yet to find one when I need help. Case point: think of your electrician and how that worked out for you.
Ouch!
Somehow it doesn't come across as intended and I'm still having a debate in my head as I write this. The right person for electrical work would be an electrician.
Sorry,
T.
Old 08-01-2012, 02:19 AM   #9
wmtire's Avatar
Forgive me, if these questions seem asinine. I am just going to go thru the simplest of things, and hope for the best. You stated it was your first travel trailer, and I am not sure of your experience level. Please don't feel insulted by anything I ask.
If you are positive that the A/C worked after this, it would have to have power that didn't come from the battery but from shore power. Most everything else could work off battery power, but not the A/C. If the A/C didn't work, you probably have problems.
Did he turn the 30 amp breaker back off in the box he installed, after ya did your tests? If this is off, and your batteries have depleted, you won't have anything work. Also, make sure the trailers power cord is securely plugged in. I know this sounds basic, but I unplugged mine to weedeat around it once, and forgot to plug it back in. My battery depleted and nothing would work in it. I started checking fuses, and other things before I remembered I had unplugged it prior.
Once you change the switch on your refrigerator to gas....The fridge should work off of gas, as long as you have turned/opened the gas valves on the tanks (normally these are closed/turned off)....and the trailer is set fairly level (which is important in gas mode). You still need some battery power to operate it in the gas mode, as your batteries help work the electronic parts of the appliance while the propane does the rest of the work. I am also assuming the dealer filled the gas tanks for you, so they do indeed have gas in them.
I don't feel good about what he may have done to your power converter, but we can hope for the best. It is also possible that the converter didn't give up the ghost right on the spot, but succumbed to prior injuries later on.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 08-01-2012, 06:40 AM   #10
TURBS's Avatar
Welcome to the forum.
This has happened way to much lately and sorry for your troubles.
I subscribed to your thread to follow your updates.
Please keep u s updated.
Get your unit to the dealer and inform your electrician of the issues.
Ron
