Old 09-06-2012, 04:22 PM   #1
Steve Jackson
sideout1961's Avatar
SOLVED Help!
Was hitching up to TT front jack was working fine one minute back the truck up went to use it and nothing no light on jack either. Fuse looks good battery connection good what could it be?
2011 Dodge Ram 5.7 HEMI
2011 Flagstaff Classic 29bhss
sideout1961 is offline   Reply With Quote
Old 09-06-2012, 04:30 PM   #2
Steve Jackson
Solved!! Didn't see the inline fuse in wire. Was loose working now
Old 09-06-2012, 04:36 PM   #3
Terier's Avatar
I was going to suggest checking the inline fuse. I had a big problem with my original jack. Glad you found the problem and fix it - good job.
Old 09-06-2012, 04:38 PM   #4
Steve Jackson
Thanks for the response anyway
Old 09-06-2012, 08:30 PM   #5
Terier's Avatar
I'm not very technical so it's not often that I can offer suggestions.
I see you also have a Tundra - how do you like it for towing? I really happy with my Tundra and might end up being a truck gal after all.
Old 09-06-2012, 08:46 PM   #6
Steve Jackson
I like the Tundra just wish I had the bigger engine. It struggles on some hills. By the way what part of So. Cal. are you from? I grew up in Cardiff-by-the-Sea.
Old 09-06-2012, 08:55 PM   #7
Terier's Avatar
Cardiff-by-the-Sea is so pretty! I'm in the Inland Empire about 40 minutes east of LA (give or take). Not too far from the Ontario airport.
I got the smaller engine too but my trailer is smaller and so far no problems with going up hills.
Old 09-07-2012, 12:36 PM   #8
Dodge Guy's Avatar
I suggest checking the inline fuse, they like to work themselves loose! you`ll have to look closely they are hard to spot!!!
02 Ford Excursion V-10 4.30 gears 5 Star Tuner Y-pipe mod Hellwig sway bar Rear Airbags
Prodigy and Dual Cam
07 Cherokee 32B
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
