Old 05-16-2013, 04:33 PM   #1
rider248's Avatar
Exclamation SOLVED - Help an electrician's son solve a wfco converter problem!
Hey, Y'all...relatively new to FRF, first post - -
I have a 2007 Forest River Shamrock equipped with a common WFCO Power Center. The RV is connected to a dedicated 30 amp receptacle behind our home; has been for more than a year with no issues. Sometime within the past 48 hrs. the AC/microwave/receptacles stopped working and I've checked switches, breakers, fuses and plugs but have found no obvious problems. I know these converters sometimes go belly-up unexpectedly but am hoping that I've simply missed a simple solution somewhere.
My father would do a double reverse somersault with a twist in his grave if he knew I was asking for help, but I prefer to defer to those with knowledge rather than stick my fingers in where they don't belong and give myself a good dose of watts, amps, ohms and "OOF's". Any and all suggestions are welcome as I'm now trying to salvage a planned Memorial Day RV trip.
The Rider Family
Wade - Kimberly - Trevin - Keaton
"Daisy Dog"
Forest River Shamrock 255 QSB Dual Slide
ROLL TIDE ROLL
rider248 is offline   Reply With Quote
Old 05-16-2013, 04:36 PM   #2
MC9
sounds like a gfci. check the one by the lav and/or near the microwave.
MC9 is offline   Reply With Quote
Old 05-16-2013, 04:41 PM   #3
rider248's Avatar
Thanks for the prompt reply! Pardon my stupidity, but when you reset the GFCI outlets by pressing the button it should then be operational, correct?
The Rider Family
"Daisy Dog"
ROLL TIDE ROLL
Old 05-16-2013, 04:43 PM   #4
rider248's Avatar
I also thought it was a GFCI and I admit I might have missed something. I'll go back outside & check the outlets. Hopefully this will solve the problem.
The Rider Family
"Daisy Dog"
ROLL TIDE ROLL
Old 05-16-2013, 04:57 PM   #5
TURBS's Avatar
Converter is runs your 12 volt items has nothing to do with 110 items.
Gfci is tripped as stated.
Should be one in kitchen and one in bathroom.
Old 05-16-2013, 05:05 PM   #6
recon33alpha's Avatar
I've been an electrician for 13 years and sometimes I have think about the RV distribution, if that helps, lol. Also be aware that GFCI's can go bad, if one won't reset it's either bad or your not hooked up to good shore power if at all.
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
recon33alpha is offline   Reply With Quote
Old 05-16-2013, 05:16 PM   #7
rider248's Avatar
Of 8 outlets only 1 has GFCI reset. When reset is pressed, nothing. When GFCI Test is pressed, nothing. I'm thinking of replacing the GFCI outlet as starters. Am I heading in the right direction?
The Rider Family
"Daisy Dog"
ROLL TIDE ROLL
Old 05-16-2013, 05:19 PM   #8
TURBS's Avatar
yes you are !
Old 05-16-2013, 05:21 PM   #9
Herk7769's Avatar
I don't think this is GFCI (at least in the camper).
The Air Conditioner does not work and that means no power to the panel at all.
This is a problem with power to the socket the camper is plugged into OR the main camper breaker is tripped. Switch the main breaker (30 amp) OFF/ then ON. A tripped breaker may not be obvious.
Is The Garage socket GFCI protected?
Is the house breaker that feeds the socket the camper is plugged into tripped?
Can you check the socket for power?
Check the camper's plug for burned tips...
HAM CALLSIGN - KC3FFW
Old 05-16-2013, 05:31 PM   #10
You right if the GFCI will not test/reset the more then likely a supply power issue. Good trouble shooting Herk
2010 GMC SIERRA
2012 GREY WOLF 25RR
2012 campouts: 42
2013 campouts:1
