Originally Posted by jl7796
That seemed to stop the spark at the plug in. I also get still get a spark at the radio fuse when I check it. The radio is not coming on when I plugged the fuse back in. For several trips I have had to unplug the radio fuse and plug it back in when I had set up camp. Now the radio is not coming on.
I don't know if this is related but if I unplug the 110 overnight I will not have enough power to raise the step
Since you say your steps won't raise while boondocking, I assume you have a motorhome. If you have 120 volt ac available, leave your RV plugged in so the converter can recharge the battery and supply power for your lights and other 12vdc appliances. If you have a residential refrigerator then you have a inverter that powers the fridge and draws 12vdc from your battery and inverts it to 120vac. Everything in your camper uses 12 volt dc power except your air conditioner. Even your thermostat uses 12vdc to control your A/C and furnace. Your furnace and 2-way(LP gas & electric) refrigerator control board uses 12vdc. If your lights are LED then they will use less than regular incandescence lights.
Everything you use will drain your batteries over night.
If my assumption is correct about you having a motorhome then you should have 2 or 4 house batteries of the same size (amp hour), group (24, 27 or other) and type (deep-cycle or marine). If you only have 2 house batteries then you will need a on-board or stand-a-lone generator
to recharge your batteries while boondocking.
Download and read the following document.
http://www.forestriverforums.com/for...do=file&id=101 This is the only one I have at the moment but there are many more in the Library section in the light green bar at the top of page of FRForums.
Forest River Forums - Downloads
Here is the section on power and electrical.
Forest River Forums - Downloads - Power and Electrical
If you can PM wmtire as he has a great list you should check out.
Welcome to the forums and have fun.
Rich
