Old 05-04-2013, 08:55 PM   #1
buzzmonster's Avatar
Spilt battery acid from trojans
Hi all
Looking for some advice here, unfortunately our beloved Trojans tipped over when in the back of the truck and some acid came out. Not too much about 1/4" from each cell. Hydrometer also bust .... So do I just add a little more distiller water and hope all is good or is there someway of replacing the acid ?
Advice daly recieved
2011 F150 Ecoboost Screw 4x4 c/w max tow
2010 Roo 21RS
buzzmonster is offline   Reply With Quote
Old 05-04-2013, 09:00 PM   #2
Should be good by just adding the distilled water.
Old 05-04-2013, 09:04 PM   #3
Denver, CO
garbonz's Avatar
Acid at the same SG as the battery. Use a real hygrometer and mix some acid with distilled water until you get a match.
Not easy
2017 Fuse 23T
Old 05-04-2013, 09:48 PM   #4
Twisty's Avatar
You can buy "battery acid"
BATTERY ACID PACK 21 OZ : Amazon.com : Automotive
As garbonz mentioned you gotta blend it properly.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 05-04-2013, 09:55 PM   #5
I lived off the grid for 6 years with deep cycle batteries (12 x 2 volt 2450 amp/hr batteries) All that I ever put in them was distilled water, the chemical reaction caused when charging creates the acid.
Just add distilled water and save our money!
_______________
2011 Ford F350 Diesel Lariat with Firestone Airbags and Ford installed Reese Elite 18K 5th
2011 Cedar Creek 36RE Touring Edition - Loaded
djkarau is offline   Reply With Quote
Old 05-04-2013, 10:07 PM   #6
Denver, CO
garbonz's Avatar
HE SPILLED ACID OUT SO ADDING WATER WILL REDUCE THE CAPACITY. In this situation you have to add acid back in of the same specific gravity.
Realt
2017 Fuse 23T
Old 05-04-2013, 10:13 PM   #7
Garbonz...the only thing in a battery is "acid". The battery doesn't know if you spilled it out or if you lost some naturally during the charging cycles. Unless you have a sealed battery or a "hydration" system on a normal deep cycle they will all loose some acid over time. All you need is normal distilled water. You will not loose any capacity. You only loose capacity when you are low on "water" or Acid" (once again, the water turns into acid thru the chemical reaction caused by charging the battery). When you buy a new battery they normally supply acid as a "kick start" so that you have a fully charged battery right from the start, however, if you were to fill a new battery with plain distilled water and put it thru an equalizing charge it would still work perfectly fine.
_______________
Old 05-05-2013, 06:45 AM   #8
RPAspey's Avatar
x2 djkarau is right.
if you read in the battery tech manual, it says that you should never add acid to a battery, only distilled water. The battery will do the rest while charging.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 05-05-2013, 06:56 AM   #9
Triguy's Avatar
x3. Distilled water is all you need. Add just enough to cover the plates and then charge. Check the water level when done and fill as needed to the "max" line.
Note, I probably would check the SG and equalize as needed. The Trojan battery manual has a description of that process if you need it or see this guide
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 05-05-2013, 07:44 AM   #10
Herk7769's Avatar
Lots of info here. Most of it "enough right" to be troubling.
The state of your electrolyte depends on the charge state of the battery in question.
If the battery is dead, the sulphate from the acid is stuck to the lead plates and the electrolyte is mostly distilled water (about 2% acid and 98% distilled water). Just top off the battery with distilled water.
If the battery is FULLY charged, there is NO sulphate on the plates and the electrolyte is mostly Sulphuric acid (SG 1.277) of a 36% acid 64% distilled water concentration.
https://docs.google.com/viewer?url=h...onversions.pdf
At 50% charge (1.172 SG), the ratio of acid to water is 24% acid and 76% distilled water.
ANY loss of acid will effect the fully charged capacity to some unknown degree. Only by doing a fully charged specific gravity test will determine the capacity reduction you have experienced.
Adding ONLY distilled water is the safest method unless you have titration facilities to calculate the exact amount of acid to replace for full functionality.
Name:	Charge Chart.jpg
ID:	29630   Click image for larger version
ID:	29632   Click image for larger version
HAM CALLSIGN - KC3FFW
