Old 03-08-2015, 11:27 PM   #1
WestCoastRV'er's Avatar
Stabilizer Switch Water Leak (Warning)
We found water in our front storage compartment today we were able to find the cause. The front stabilizer switch has only foam to stop water from entering the storage bay. I removed the switch, applied dicor (no sag) behind the switch and replaced. Figured we should also check the rear switch which also had signs of water damage.
Don't let this happen to you.
2011 2902ss Rockwood Ultralight
2008 Grand Cherokee 3.0L Diesel (255 hp @ 2900 rpm / 430 lb-ft @ 1,400-2,800 rpm)
3P ProPride Hitch
RV Mods
Wandering RV Life
WestCoastRV'er is offline   Reply With Quote
Old 03-09-2015, 12:36 AM   #2
Better to put them in a compartment.
Lippert Components RV Electric Stabilizer Jack Switch Harness Box Kit RV Trailer | eBay
Name:	Jack Switch box.jpg
Old 03-09-2015, 04:53 AM   #3
B and B's Avatar
I did both the one front landing gear and the rear stabilizer switches. Bought Menards while at Goshen. These are spring loaded covers are aluminum and seal better than stock Cooper outlet covers. Required from cutting of original switch Bezel and held into the flip cover with hot melt glue. Siliconed sealed the flange to the trailer. One other reason is I can lock these to prevent kids in the neighbourhood from messing with landing gear or jacks.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
leak, water, water leak
