Old 08-28-2016, 06:16 AM   #1
stabilizers
I own a forest river wildwood x-lite. the stablizers only work with the remote control. the manuel switches quit working. can you give me some advice. e-mail - jandcnormand@gmail.com
oden normand is offline   Reply With Quote
Old 08-29-2016, 12:26 PM   #2
Head Rambler
I'll be glad to help, but I'm not good for emailing you. If you're going to visit the forum from time to time, I'll be glad to work with you to figure out the problem.
Your problem could be the switches or just a blown fuse. The manual switches and remote operation are fused separately.
Gotta go campin!
Old 09-07-2016, 09:53 PM   #3
Same problem with mine. Quick action up/down on the front switch caused it. Now trying to find the fuse/CB. Anyone have a clue?
Wildcat Maxx TT
dsaur is offline   Reply With Quote
Old 09-08-2016, 08:37 AM   #4
TURBS's Avatar
Look for a resettable circuit breaker up by the battery.
Old 09-08-2016, 09:16 AM   #5
Stormrider151's Avatar
Mine did that.The fuse was on the LCI control board. It's a set of fuses and relays separate from the converter. I finally found mine behind a false wall in the pass though. I used the remote to extend and retract the awning and listened for the relay click. It could be anywhere in your unit. Usually behind a removable panel.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost
Getting old ain't for wimps!!!
Stormrider151 is offline   Reply With Quote
Old 09-10-2016, 07:16 PM   #6
Thanks for the replies. Turns out the fuse was on the LCI panel as Stormrider151's was. Not easy to get to, behind the entertainment center and wiring. As I dug around during this adventure I found several loose/stripped screws on panels and trim work. Hope this isn't the norm for this coach.
Old 09-10-2016, 09:02 PM   #7
I'm glad you found it. Locating that board can be a challenge. My last trailer it was located right next to the water pump. GENIUS. I like to open up all the panels I can on a trailer to see whats behind them. You find good and bad stuff. Like tap points for upgrades and daylight showing through a seal.
