Old 01-08-2016, 03:46 PM   #1
Send a message via Yahoo to carluv
Steps
Having a step problem, besides the bolt shearing off. That is another story.
Had steps replaced after bolt problem , and now they don't want to go in. If the engine is running and you get out and close the door, it may take 2-3 min before they go in. If they go i and you open the door again right away, they will not come out and you have to climb out the door or climb in if you are outside.
Anyone else have this problem?
carluv is offline   Reply With Quote
Old 02-12-2016, 08:51 PM   #2
SeaDog's Avatar
check the electrical connections to the steps, I had a problem with the steps and that what it was the wires were corroded and not passing enough amps for the motor to run as it should
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 02-13-2016, 06:38 AM   #3
SeaDog,
Thanks for the info. I will check the wires and see what happens.m
Old 02-13-2016, 06:58 AM   #4
bubbles's Avatar
One issue that is common to both your issues is a good ground. The large green wire that is grounded to the step chassis is the main grounding point but the mounting bolts for the steps must also make a good ground through the unit. These points should be bonded metal to metal (no paint between points etc.). Another common issue is the step controller itself.
Old 02-13-2016, 10:38 AM   #5
Bubbles,
Thanks for the info. I will check all the grounds first, but I think it is the controller also. The new steps worked fine for the first 2-3 months. I will clean all the connections and see what happens. I looked up under the steps and all the wires were tight, but will keep everyone posted.
They are still under warranty if I can't get them working right. Hate taking it to the RV shop.
