Old 08-25-2016, 07:46 PM   #1
Still trying to Locate the Xantrex 1000 Watt Inverter in my 2016 Dynamax REV 24CB
Hello again to the RV community out there, i am still trying to locate the Xantrex 1000 watt inverter that is installed in my
2016 Dynamax REV 24CB. I have looked under the pull up bed, i pulled the AC / DC Fuse Panel cover off and found the AC to DC Converter.
However Still no luck on locating the Physical location or access point to the 12 volt to 120 volt Inverter. Any other suggestions on it's location would be greatly appreciated.
Thank you
John & Dorothy driving our new "Gypsy"
jjpp1 is offline   Reply With Quote
Old 09-20-2019, 09:22 AM   #2
Thank you
bclemens I have the same question, I'll add if there are any drawings/docs that explain the inverter location/wiring. Thank you.
UncJimmy is offline   Reply With Quote
cat, inverter
