Old 04-20-2013, 04:19 PM   #1
FNG
fishman's Avatar
Strange 12v Issue
My 12v systems are good on shore power but I'm not getting 12v to my house fuse panel when I run on battery. The battery is good and powers everything external prior to the house panel so everything 12v after the panel is dead. All the re-settable CBs next to the battery show good voltage on the downstream side. Also, if I disconnect the battery when on shore power, I get the exact opposite symptoms: this inside 12v stuff works but the outside does not. Would they have buried a fusible link somewhere deep in the bowels of the camper on the long run btwn the battery and the panel? I'm pulling the insulation sheets underneath and chasing the run along the inside frame rail. Will update when I find something.
If anyone has any ideas for what I should be looking for, please chime in!
2012 Wildcat 344QB w/ Outside Kitchen
2011 F350 6.7 Lariat Crew Cab LB SRW FX4
fishman is offline   Reply With Quote
Old 04-20-2013, 04:32 PM   #2
Owner/Operator
RodeoGeorge's Avatar
I don't know what type of Converter or panel you have, but on my panel there are two fuses on the battery input which if blown will exhibit what you are seeing.
On my panel, they are the topmost fuses, and there is not "blown fuse" indicator on these two fuses.
RodeoGeorge
2013 Rockwood 8289WS
Mods: Central Vac, PI EMS-HW50C, 2025RV, (2) SCS225 Trojans, PD9260, Awning Remotes & LED Lights, Eliminators, External Water Filter,, Intellijacks
2008 RAM 3500 Cab&Chassis Hauler Bed, B&W Companion Hitch
All My Modifications are at this link:
http://www.forestriverforums.com/for...ons-36212.html
RodeoGeorge is offline   Reply With Quote
Old 04-20-2013, 04:48 PM   #3
Triguy's Avatar
There is an inline fuse or resettable breaker between the battery and the converter. On my trailer, its located underneath the trailer, at the driver's side corner - about four feet from my batteries.
It could also look something like this - see the little button?
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-20-2013, 06:01 PM   #4
FNG
fishman's Avatar
RodeoGeorge- thanks for the feedback. I checked but do see any mains on the 12v side of my panel.
Triguy- what on Earth were they thinking! I'll follow my main wire back and look for a breaker.
Thanks again folks!
Old 04-21-2013, 10:51 AM   #5
FNG
fishman's Avatar
Angry Fixed but Annoyed
First I want to thank the forum members that assisted with my troubleshooting.
I chased the 12v main wire the entire length of the underside frame rail looking for the hidden breaker. I never found an additional breaker but with all the tugging and yanking on the wires, I found the problem. When I came back up front to the battery compartment I noticed the main wire had fallen completely from its connector! Then I noticed about half of the strands had been clipped off. I'm guessing the factory genius that did the assembly made a bad first crimp with a tool that wasn't big enough for 6ga wire. Then rather than get a new connector and the right tool, he trimmed some strands and forced it back into the already crimped connector and tried to squeeze it a bit more. One way or the other, this was some shoddy work and resulted in a senseless waste of my time.
OK, I'm done ranting. Time for a cold beer.
From top to bottom the attached images are:
1. original connection
2. loose wire
3. clipped strands
4. final fix
Name:	original (640x480).jpg
ID:	28567   Click image for larger version
Name:	loose (640x480).jpg
ID:	28568   Click image for larger version
Name:	clipped (640x480).jpg
ID:	28569   Click image for larger version
Name:	final (640x480).jpg
Old 04-21-2013, 11:55 AM   #6
Lynkage's Avatar
You did good Fishman!! Better you to find and fix than a possible "nother" failed fix!
Now you know your trailer even better.
Shane & Antoinette
2012 Ford F-450 SuperDuty
2013 Crusader 355BHQ
Lynkage is offline   Reply With Quote
Old 04-21-2013, 12:00 PM   #7
Vinster30's Avatar
Glad you found the problem. Makes you think that some people are at work just to draw a pay check. Not taking any pride in their work.
Sounds like you still made happy hour!!!
Vinster30 is offline   Reply With Quote
Old 04-21-2013, 02:34 PM   #8
FNG
fishman's Avatar
Happy hour and then some! Watching to O's struggle w/ the Dodgers before heading back out to knock a couple more items off the honey-do list.
