Old 04-18-2013, 09:45 AM   #1
Oakman's Avatar
Strange 50 amp service
This 50 amp connection at the KOA park in Washington, PA was a first for us. Normally the breaker is marked as 50 amp, this one was two individual 30 amp breakers. Iíve never seen that before. The surge protector didnít report any issues so I guess this type of connection is OK. We've never encountered this before.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 04-18-2013, 09:50 AM   #2
TURBS's Avatar
I am guessing it's not a "true" 50 amp service ?
Maybe it was wired for 50 amp and they just used two 30 amp breakers?
Old 04-18-2013, 10:03 AM   #3
wmtire's Avatar
I've read of similar in other forums. Like Turbs stated it's not a true 50 amp.
A TRUE 50 amp service will consist of TWO 120 volt hot legs, each providing 50 amps a piece.........or in actuality 100 total amps. I always refer to this kind of service as a 50 (x2) amp service to avoid confusion.
It appears that this service is providing TWO 120 volt hot legs, but at 30 amps a piece, or 60 total amps.
You will sometimes run across where a campground will cheat, and wire both hot legs from the same 50 amp side...........in which case you only have 50 total amps.
Since 50 amp RV's run off of 120 volt..... from either side, it all works correct. It just limits your total amps that can be used.
2011 Flagstaff 831 RLBSS
I went to my first meeting of Hypochondriacs Anonymous last night. I came out with more diseases than I went in with.
Old 04-18-2013, 10:17 AM   #4
Actually we don't know if this is 240 or not. It could still be and they just didn't use linked breakers. For sure it's no more than 60 amps (instead of the normal 100). If our suspicions are right however, and this is single-phase, it's still a very bad situation. See my thread on this topic: 50 Amp Service has to be 240v
The neutral wire on our 50-amp RVs is intended to carry no more than 50 amps. What we see in this picture could have it carrying 60 amps, which could cause overheating and fire. Note that Progressive Industries is upgrading their protectors to give an error for this situation. I hope you will ask the campground to fix this bad situation. If they won't, we should send an email to KOA headquarters.
Old 04-18-2013, 10:35 AM   #5
TURBS's Avatar
VERY good idea !
Old 04-18-2013, 10:37 AM   #6
wmtire's Avatar
Oakman, if you have a multi-meter with you....you can check across the two hot legs(Y and X) in the outlet to see if you get 220/240 volts or 110/120 volts.
The voltage between Y and X should be 240-Volt, X and W 120-Volt, Y and W 120-Volt, X and G 120-volt, Y and G 120-volt, W and G 0-Volt
Old 04-18-2013, 10:52 AM   #7
Herk7769's Avatar
My money is on a bad 50 amp dual pole breaker and the campground tech only had 30 amp breakers in his tool box. They are brand new and the others are ratty.
Did you happen to look at the other pedestals on that circuit?
HAM CALLSIGN - KC3FFW
Old 04-18-2013, 10:56 AM   #8
TURBS's Avatar
I am curious as to why there is a "20" amp breaker in the box.
surely the household receptacle that you do not have pictured is only a 15 amp receptacle?
Old 04-18-2013, 11:01 AM   #9
Oakman's Avatar
The thought of looking at other pedestals didn't even strike me Herk, I wish it had. That KOA is in rather rough shape so seeing that setup didn't really surprise me.
I guess I'll be buying a multi-meter now, and I will send KOA a photo to see what they say.
That particular KOA was one of the worst I've stayed at in recent years.
Bob and Joyce
ATU Local 788
Old 04-18-2013, 11:05 AM   #10
Oakman's Avatar
I haven't paid too much attention, but I think most of the pedestals I've seen have a 20 amp breaker and not a 15. I could be wrong though, lately I've discovered that I can't place any trust in my memory.
Bob and Joyce
ATU Local 788
