Old 08-15-2012, 08:54 AM   #11
caper's Avatar
The same thermostat runs the furnace which is 12 volt.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 08-15-2012, 09:30 AM   #12
onetonford's Avatar
Actually thermostat runs relay or contacts depending on thermostat that runs furnace. If you don't have 12volts to furnance it wont work but ac still will work...
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
onetonford is online now   Reply With Quote
Old 08-15-2012, 12:03 PM   #13
Herk7769's Avatar
Yes; One thermostat but two different sets of control power (one provided by the furnace and one provided by the air conditioner) and contacts.
HAM CALLSIGN - KC3FFW
Old 08-15-2012, 01:27 PM   #14
papap's Avatar
On my Solera the 12volts come from the camper 12 system. not a AC tranformer.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 08-15-2012, 01:47 PM   #15
Coachmen Adrenaline
The AC control unit is powered from 12V. The thermostat tells it what to do. Check out page 9: http://www.dometic.com/FileOrganizer...llation_EN.pdf
We run 12Vdc and 120Vac through the roof to the AC opening. So if the 12Vdc is dead, the control unit inside the AC would not be functioning. we use the Brisk Air AC's on the class C line.
jamiller45 is offline   Reply With Quote
Old 08-15-2012, 03:07 PM   #16
Herk7769's Avatar
Thank you John.
I had no idea the Class C units had a "Comfort Controller" that has a separate 12VDC run (fused at 3 amps). My Coleman Mach III is not set up that way.
Where is that 3 amp fuse located?
Do all Motor Homes have this type system?
What trailers have this unit?
Old 08-15-2012, 04:16 PM   #17
onetonford's Avatar
I see the fan motor is twelve volts to circulate air when traveling down the road unlike the trailer unit which have no reason to run the fan when no bodys in the trailer unlike the motorhome which people occupy the whole unit and need to keep cool air in whole unit.
2011 25 RL Wildcat
Old 08-15-2012, 04:36 PM   #18
Herk7769's Avatar
So, back to the OP.
There should not be a 12 VDC run to the roof air conditioner, right?
Old 08-16-2012, 06:17 AM   #19
Coachmen Adrenaline
Originally Posted by herk7769 View Post
Thank you John.
The 3 Amp fuse is built inside the AC module also. We supply that 12Vdc with the same circuit we wire for all of our roof vent/fans. I believe it is more just to power a relay inside than anything...I've never dove too far into it other than knowing what we have to provide the AC module in order for the AC to work correctly.
I am uncertain who all uses the Brisk Air AC's other than us. We don't have set standards even within FR, so each division and product is free to find what works best for them.
Also, I forgot I was in a trailer thread. oops. I didn't mean to muddy up the waters with other product info. Please forgive me.
Old 08-16-2012, 06:24 AM   #20
Herk7769's Avatar
No, you are quite correct!
It is not a trailer thread. It is in General Tech.
This happens quite a lot actually and a hazard of putting "generic" tech support by appliance in one place. Sometimes I make assumptions based on my experience (OK, it happens a lot) with trailers and assume it applies to everyone. I am learning.
I had no idea motorhomes could have both AC and DC FEED requirements, since all my trailer air conditioners never did. Lesson learned again.
