Old 08-10-2013, 09:11 PM   #11
At least mine is under warranty
'14 Wildcat Maxx 28rkx
'04 Ram 2500 Cummins
Tedscastle is offline   Reply With Quote
Old 05-13-2014, 11:00 PM   #12
OK. It has been quite a while since I first report this issue and the dealer has done nothing. Since it was intermittent, they could not duplicate it. When I had in in the fall, I don't think they tried. Last week I brought it armed with a video. Of course it was like pulling teeth to get anyone to watch.
Finally, the called and said that there were no problems and the only time they could duplicate the issue was when it was plugged in and attributed the 6.5 am draw to the trailer being plugged in and the inverter was draining power. ????? They basically laughed at me and said that there was nothing they could do except sell me a pair of 6v batteries.
Last weekend, the same thing happened and zapped the battery. This time, I had a hard time getting it to stop drawing 6v, maybe due to the low battery charge at the time.
Anyway, Yesterday I sent an message to the Wildcat Maxx Facebook page and customer service at Sureflo stating what I had been told on this thread. Sureflo wrote back and recommended adjusting the pressure back 1/4 turn and sent a diagram on what to do. The pump already sounds different when turning off. We'll see what happens when I take it out.
So much for warranty service at the dealer.
Old 05-14-2014, 08:11 AM   #13
Herk7769's Avatar
Just saw this thread. I am in complete agreement that you most likely have a pressure cut out switch problem; but there could also be an issue with the motor itself.
Even if the cut out switch is bad, the pump should continue to run in a "no flow" condition. There are 3 rotor pumps in the plastic "head" and there is a check valve in front of each one. (See parts exploded view attached).
Normally, once the back pressure in the lines reaches the cut out switch pressure, the switch removes power from the motor, the rotors stop turning, the check valves slam shut and pressure is held in the lines.
If the rotors are binding (debris in the rotor housing?), as the back pressure in the lines starts to build, it perhaps is slowing the pump rotors to the point where they just stop turning before cut out pressure is reached.
Turning back the pressure switch to the point where the motor actually stops before the rotors bind up might only be curing the symptom and not the disease.
I would ask them to ship out a rebuild kit or new pump.
Name:	Shurflo Pump IPB.jpg
File Type: pdf Classic Pump - pds-2088-422-144_444_.pdf (192.4 KB, 22 views)
File Type: pdf Classic Pump - pds-2088-422-144_444_ (1).pdf (150.7 KB, 17 views)
HAM CALLSIGN - KC3FFW
Old 05-14-2014, 10:57 AM   #14
Herk
Thanks for your ideas. We'll if their idea works. I'm just thrilled that they wrote back so quickly after the dealer basically ignored me.
Thanks for the email. Application Engineering that if you are drawing 6.5 amps while the faucets are closed that it may be because the pump is not shutting off due to the pressure shut-off being higher than the maximum by-pass. Please see the attachment and adjust the pressure adjustment counter-clockwise in 1/4 turn increments
Old 05-14-2014, 12:07 PM   #15
VinceU's Avatar
Originally Posted by Tedscastle View Post
Herk
That factory advice is interesting, who'd ever think the pump has a relief valve bypass (return) Can you post the attachment? Tks
Old 05-14-2014, 12:19 PM   #16
Here is the attachment that Sureflo sent.
File Type: pdf 4008 4008 Pressure bypass adjustment procedure (3).pdf (40.6 KB, 51 views)
Old 05-14-2014, 01:46 PM   #17
VinceU's Avatar
That answered the question, most RV's are fitted with a 3 lobe unit with suction strainer and discharge check valve/with auto cutoff. The 4008 Revolution is a newer 4 lobe higher capacity pump with pressure controls built In, if set right! Tks!
Old 05-14-2014, 04:21 PM   #18
Herk7769's Avatar
That is a pretty cool pump all right.
pump, water, water pump
