Old 02-14-2014, 08:43 AM   #11
Originally Posted by mlsa3 View Post
I know this is probably a stupid question but here goes. I've been researching camping spots for our next trip. I've seen where they list 50 amp sites but do not mention 30 amp which is what our Aframe uses.
When they mention 50 amp does that automatically include 30 amp also?
Not always! Youroo!!
ID:	46249   Click image for larger version
Old 02-14-2014, 08:43 AM   #12
wmtire's Avatar
Originally Posted by travyp View Post
Correct me if I'm wrong but isn't it understood that EVERY campground has 30 AMP? Now not every campground will have 50 AMP and that is why they advertise it. So yes, if you pick a site that is 50 AMP, you might want to have the dog bone but I generally assume every other site would have 30 AMP unless specifically stated otherwise.
There are a few campgrounds (and camping spots) that only have 50 amp service. As others pointed out, these places usually have an adapter they loan out to the 30 amp RV'ers when needed.................but it doesn't hurt to have your own anyway. I have encountered several spots at my local campgrounds that had bad/loose 30 amp outlets, and thus needed my adapter to plug into their 50 amp outlet. The adapter is 50 amp male, 30 amp female.
You can usually find these dogbone adapters at your local Wal-mart in their RV section. We have discussed before how Wal-mart has the description wrong but the picture correct for this product.
http://www.walmart.com/ip/Road-Power...nches/16817357
or if you are an Amazon shopper:
http://www.amazon.com/Voltec-16-0050...amp+rv+adapter
or a Camping World customer:
http://www.campingworld.com/shopping...-handles/69614
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-14-2014, 09:10 AM   #13
AKA: 'tiredTeacher
awellis3's Avatar
OK - you are corrected. I just learned this 2 weeks ago on a long trip to Florida. Many RV parks who cater to long-term campers (as in Florida) don't go through the added expense of running multiple services.
Now you are correct. The 50A-only campgrounds tell you on their websites and reservation forms to bring your adptors. Not all have "loaners."
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 02-14-2014, 09:30 AM   #14
Teach
I read too much into the original post.
How I saw the question is this. The OP sees sites that specifically state 50 AMP. No where do they see anything mentioning anything about 30 AMP on any of the sites. What I was stating is that the OP doesn't necessarily have to worry about picking a special site that states 30 AMP because it is understood that they "all" (being anything not stated at 50 AMP) to be 30 AMP. Guess I should have just answered the only real question in the post.
2013 Puma 30DBSS (Parked at Seasonal Site)
2001 Ford F-150
travyp is offline   Reply With Quote
Old 02-14-2014, 10:08 AM   #15
Kaadk's Avatar
To add another scenario to the need for a 50 to 30 adapter. I once arrived at a campground where the shared a pole for every two sites. The pole had a 30A and a 50A. When I pulled in the other site was already occupied and that guy was plugged into the 30A. If I didn't have an adapter with me, I would have been S.O.L. on having power.
The surest way to lose is to play Marco Polo with a ventriloquist.
Old 02-14-2014, 11:50 AM   #16
Herk7769's Avatar
This happens a lot.
Additionally, I have been in spots where the 30 amp socket was so corroded or loose that it was unusable/dangerous. Plugging into the 50 amp socket with an adapter has saved moving several times.
HAM CALLSIGN - KC3FFW
Old 02-14-2014, 12:09 PM   #17
dcheatwood's Avatar
Almost always. I have never found a campground that didn't have 30amp spots with the 50amp sites, but I read about it. In those cases, the campground offered 50amp to 30amp adapters that they loaned out for folks in 30amp rigs.
My experience also. And 20 amp outlets are usually there too.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 02-14-2014, 12:12 PM   #18
TURBS's Avatar
not always are they 20 amp outlets either but rather 15.
Old 02-14-2014, 12:22 PM   #19
Brother Les's Avatar
In the last two years I had to use my 30 to 50 (my trailer is 30) twice as that is all they had.
One time I had to use my 30 to 15 adapter, as the last guy in that spot had pulled out and had forgot to unplug his power cord. Shattered the plug. The former camper 'forgot' to tell the campground host and as it was a Friday night and was told it could not be 'fixed' until Monday morning.
Brother Les
Old 02-14-2014, 03:01 PM   #20
Chuckinca's Avatar
Originally Posted by herk7769 View Post
This happens a lot.
DITTO.
Also have been in parks where all the working 30 amp sites were taken and only 50 amp was available. Sometimes they will lend you a 50 to 30 adapter and sometimes not - bought one just in case.
2018 Flagstaff 29KSWS
2008 Ram Laramie 3500 Megacab 4x4 Cummins 6.7L Turbo Diesel
Chuckinca is offline   Reply With Quote
