Old 02-14-2014, 11:25 PM   #21
Oklahoma Proud
MillerTime's Avatar
I know there were some links, but the adapters are only about $15-20 at walmart and other stores- at least around here.
Heck I saw some for $12 at a local tool store that were the same as walmarts- I wanted to buy a couple extra of each, but didnt....but still thinkin bout it though.
oops. forgot to check mark that stupid box again!
Old 02-14-2014, 11:50 PM   #22
mark0224's Avatar
Truthfully after reading all the posts I don't think it was a stupid question and after reading all the posts would say no if it says 50 amp don't count on 30 amp also. Some of the pictures of pedestals that were seen , did seem to have 15 amp with both 30 and 50 amp. This would not run AC but will run everything else. Ck the breakers they could be 20 amp outlets either way you can plug into them with an adapter safely.
mark0224 is offline   Reply With Quote
Old 02-15-2014, 10:29 PM   #23
Fulltime family RVer
I agree, not stupid at all! Plus- you never know if you don't ask.
Old 02-16-2014, 04:58 AM   #24
Oakman's Avatar
A few years back we stayed at Flagg Ranch RV park which is located between Grand Teton NP and Yellowstone NP in Wyoming. All of their sites were 20 amp only. I have read that they are finally upgrading their electric but I don't know if that is a fact or not.
BTW, after opening the electric box it took me a bit to figure out where that 20 amp outlet was located. Here's a pic.
Name:	IMG_5650 - Copy.jpg
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 02-16-2014, 05:55 AM   #25
Truth B Towed's Avatar
Originally Posted by Iwannacamp View Post
I remember a post about how they arrive at the 50 amp service...or at least residential 50 amp. They use one side as L1 120v 20-30 amps then L2 as 120v 20-30 amps to get the total of 45-55 amps 120v split from a 220v service... I was like what ?? I can do basic electric and am fairly confident about all home psrojects, but I wasn't clear on this deal. I know that you have 2-120v legs, 1 neutral and one earth gound. They were splitting a 50 amp RV site to (2) 30 amps with a cord and running two connectors inside the RV. I am good on most of that until they mentioned the actual pole being 220v and "the RV" connector split the service. I was like "what". I decided i would have to research... classified as "something else to worry about"
Huh? english please... adapters is a must for first time TT buyers, you never know when you will need one.
2008 Silverado 5.3 tow package
2013 Roo 25rs
2014 nites booked 10
Truth B Towed is offline   Reply With Quote
Old 02-16-2014, 08:33 AM   #26
AKA: 'tiredTeacher
awellis3's Avatar
Originally Posted by Kaadk View Post
To add another scenario to the need for a 50 to 30 adapter. I once arrived at a campground where the shared a pole for every two sites. The pole had a 30A and a 50A. When I pulled in the other site was already occupied and that guy was plugged into the 30A. If I didn't have an adapter with me, I would have been S.O.L. on having power.
May I add one more? We camped at an older RV park and my 30A pole breaker was, to use a techical term, "tired." It kept tripping when Penny plugged in her hair curlers. My on-board breakers never trip under these conditions. The adaptor allowed me to tap into the 50A, whose breaker hadn't had as much use.
Teach
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 02-16-2014, 09:40 AM   #27
rowdydog77's Avatar
I have a 30 amp trailer, if I plug into a 50 amp breaker using an adapter won't I be getting 220v? Aren't all 50 amp breakers 220v?
2002 GMC Sierra C2500 HD 6.6L Duramax Diesel
2013 Sabre Silhouette 291BHTS
Pat, Michele and 2 old dogs, Shug & Sissy
rowdydog77 is offline   Reply With Quote
Old 02-16-2014, 09:53 AM   #28
In a case like this I would want my own adapter.
I don't trust loaners - especially when it comes to electrical matters and my stuff.
hud
Hudlow is offline   Reply With Quote
Old 02-16-2014, 09:53 AM   #29
wmtire's Avatar
In simple terms, a 240 volt service consists of 2 out of phase 120 volt legs. You commonly call each 120 volt leg , L1 and L2.
You only get 240 volts when you combine the L1 and L2 legs. If they are kept separate, then each leg is only 120 volts.
A 50 amp RV, normally utlilizes each leg separate. The RV electrical panel uses L1 to power certain things, and uses L2 to power other things................never combining the two legs to get 240 volt power.
When you use an adapter, it only takes one leg (either the L1 or L2 but not both from the pedestal) and provides 120 volt to your 30 amp trailer..............and doesn't combine them to get 240 volts since it's only actually using one leg.
On the opposite spectrum, you can use a different kind of adapter that let's a 50 amp RV plug into a 30 amp outlet. This adapter shares the 30 amp 120 volt to both the L1 and L2 sides of the RV. However you are limited to 30 amps total power when connecting to a 30 amp outlet, instead of the 100 amps normally available. (50 amps per leg X 2)
This site may help explain it better.
http://www.rvcruzer.com/electrical/chapter3.php
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-16-2014, 10:01 AM   #30
(good explanation wmtire, you got there before I did)
