Old 11-25-2015, 07:57 AM   #1
Sunseeker 2013 Battery Questions
Just took delivery, very excited. It will be a month or so before we head to warmer climates. A few newbie questions, if I may:
1) If stored outside, should the battery(s) be pulled and place on a trickle charger?
2) If not, I can run electrical to the RV, would that suffice in keeping everything happy?
3) Where exactly are the batteries?
Thanks for your patience and help
The Millers
LTRVing is offline   Reply With Quote
Old 11-25-2015, 08:23 AM   #2
A32Deuce's Avatar
Welcome to the group. Any water on board? If battery's are fully charged, just turn off bat. disconnect switch near entrance door. I believe bats. are under a step. Did not say what model you have. My SunSeeker's are under a step. If you leave it plugged in, then you must check water level in the bats. The converters that come with these units are not staged and put out a constant voltage which tends to boil off the water in the bats. Just refill with distilled water NOT TAP water.
A32Deuce is offline   Reply With Quote
Old 11-25-2015, 08:34 AM   #3
Thanks for the welcome, this forum fills in lots of knowledge gaps for us. We're in the North and it gets cold, no water on board, everything water related winterized ok. Model is 317ODS. I assume that the engine battery may not start the coach after a month in the cold, hence some of my concern.
Old 11-25-2015, 09:23 AM   #4
A32Deuce's Avatar
Well I'm in South Jersey and it sat from November till we left in the beginning of February, and started right up. Same as my regular vehicles when we come home after 3 months. They all start right up if the bats. are in good shape. As long as it is charged, it should be fine. There should be a booster switch to use house bats. to help start coach. Under drivers left side of the seat on mine.
Old 11-25-2015, 12:01 PM   #5
From my understanding, batteries have a much lower rate of self discharge during colder temperatures so they will stay charged for a longer time during winter months than hot summer months. I have a 3010DS and live in Minnesota where it gets very cold and plan to run both the genny and engine once a month during the winter months to keep all the batteries charged. There is no electricity source close to where it is stored so I do not have an option to keep it on shore power.
lucky55616 is offline   Reply With Quote
Old 11-25-2015, 12:25 PM   #6
A32Deuce's Avatar
That isn't a bad idea for the genny as long as it is under a load. The coach would do better if you drove it. When the genny runs under a load and fully charges the bats. then it will charge engine bat. Unless you drive the coach and get to operating temp. really does more harm. You could run y hook up a charger to coach bat and charge it.
Old 11-25-2015, 02:07 PM   #7
LTRVing:::: Welcome and congrats on new rig. You are at the right place for any assistance. I have found everyone really helpful and friendly. I have a 2013 3170DS AND LOVE IT. If you read a lot of these posts you will see mine where I had had problem of leaving my rig plugged in last winter and cooked the batteries. The style converter does not drop down to just trickle to maintain charge. This year I am using a seperate trickle charger to maintain. I still will check battery status and remove charger until I see a drop. I used compressed air to winterize for the first time and found it simple to do. I put antifredze in black and grey tanks and traps but do nof put it in water lines becausd it takes too long to get taste out . Cannot wait for springtime.
OKpete is offline   Reply With Quote
Old 11-25-2015, 04:32 PM   #8
Tom48's Avatar
We have a fairly cheap converter. It is IOTA but four $19 retail I added a plug in module that makes it a full on 4stage charger and for the love of me, at $19 retail, I do not understand why it is not built in to the thing from day one. Take away the stock connection port on the converter and the case and packing for the adapter and it would have been a $2 difference it mfg cost.
Tom48 is offline   Reply With Quote
Old 11-25-2015, 05:51 PM   #9
The Millers
Under the steps. I keep shore power it will keep batteries up.
Myrle is offline   Reply With Quote
Old 11-25-2015, 07:10 PM   #10
Delco Bobby's Avatar
The FR owners manual says that it is a multistage charger and so does the literature for the converter. Here is the quote from the owners manual...
"Battery Charging The converter also operates as a battery charger, when it is connected to a 110 volt power source. If the battery is below its full charge, the converter charger will begin operation at a rate that reflects the level of discharge. When the battery is again fully charged, the converter charger drops its charging level back to a maintenance level, to keep the battery fully charged. "
Now I have read posts which state that the supplied converter can fail to work properly and that will not be noticed by you a battery problem occurs. Supposedly the converters can be tested for proper function.
Some people replace their converters with a higher quality American made unit which is probably the smart path if you planned on keeping your RV for years. Since you are new to this like me, it is probably smarter to keep it the factory one if it works. Just check the fluid levels.
Bobby
2017 Dynamax REV 24RB
2018 Ford F-150
Delco Bobby is online now   Reply With Quote
2013, battery, sunseeker
