Old 10-07-2015, 07:47 PM   #1
Sunseeker not charging batteries
Need some help. Sunseeker 2900' 2012.
I had the CO2 alarm for low voltage. Had both batteries replaced, but they are not being charged. Check the converter and it is outputting 13.6 volts, but this doesn't seem to be getting to the batteries.
Checked the breakers in the control box, all ok. Could it be cables or the control electronics? Any thoughts would be appreciated before I go to the dealer!
Flying Frank is offline   Reply With Quote
Old 10-07-2015, 07:48 PM   #2
TURBS's Avatar
You need to find a manual resetable circuit breaker near your positive cable.
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "27 nights"
Old 10-07-2015, 08:18 PM   #3
Head Rambler
I agree with Turns that it's probably the Short-stop circuit. However, it may not be a manual reset unit. It could be an automatic unit that has failed.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 10-07-2015, 09:04 PM   #4
TURBS's Avatar
True.
TURBS
2011 32bhok Sabre
Old 10-07-2015, 09:24 PM   #5
Herk7769's Avatar
Like most motor homes, the Sunseeker has a Battery Control Center (BCC).
Inside the BCC there are resetable current limiters that prevent short circuits or momentary overloads on one battery (Coach or Starting) from affecting the other battery.
Here is a "typical" BCC wiring diagram and even though it is not for your motor home, they are fairly generic.
The Battery Isolation Relay may be inside the BCC or a separate unit.
Corrosion at any of these connections can cause failure of the coach or starting battery (or both) not to charge.
Name:	Battery Control Center Schematic FR.jpg
ID:	90961   Click image for larger version
ID:	90963   Click image for larger version
ID:	90964   Click image for larger version
ID:	90965   Click image for larger version
ID:	90967   Click image for larger version
File Type: pdf BiDirectional Isolator Relay Delay.pdf (105.0 KB, 40 views)
HAM CALLSIGN - KC3FFW
Old 10-08-2015, 01:48 AM   #6
Mike968's Avatar
I have a 2012 2900 also and it happens to be in my driveway, if you would like me to check voltages or trace cxts pm me and I'll give you my number.
Mike968 is offline   Reply With Quote
